brake lights always on after pedal swap (resolved)
tektic
ronkonkoma, ny
I swaped an auto set for manual DSM pedals. I used all the stock plugs. The rear lights are on as soon as I put the battery on. Anone ever run in to this issue?
Resolution: I connected a 2 pin conector to a switch that was on my clutch pedal. This connection is not to be used.
Thanks toybraker for the pm
You need to check the settings of your brake light switch. Likely needs adjustment.
Fish
Idaho Falls, ID
I had this problem with my base model, the piece on the pedal arm that pushes against the brake pedal switch fell out. I used a panel clip in its place. Or the switch may need adjustment as iceman said.
tektic
ronkonkoma, ny
It doesn't seem broken. Maybe I used the wrong switch? There's one screwed into the bottom of the clutch pedal that doesn't have a wire any more. I don't remember what was what I did this all a year ago. What color is the brake switch? Mine is black.
Fish
Idaho Falls, ID
Both switches are black, the clutch pedal switch is square with a 2 wire connector and the brake pedal switch is round with 4 or 5 wires, I couldn't tell in the dark.
tektic
ronkonkoma, ny
I'm really confused now. I pulled the 4 pin connector out of the brake switch and the lights stayed on. I pulled the 2 pin connector from the clutch switch and the lights went out.
I'm too hung over to hang out upside down under my dashboard to figure this out right now.
