Brad Anderson's 1991 Galant VR-4 1459/2000
Turbo99
Haverhill, MA
Owner: Brad Anderson
Message Board Name: Turbo99
Year: 1991
Number: 1459/2000
Best 1/4 mile time: N/A
Dyno: N/A
Motor:
• 6 bolt stock original VR-4 longblock (down to the head studs and head gasket) with ~84k miles on it
• Stock cams
• NGK BR8ES Plugs
Fuel:
• Walbro 255 fuel pump
• Buschur FPR
• FIC 1150's
Intake & Intercooler:
• FP Intake
• Buschur 1g FMIC and piping
• Greddy Type-S BOV
• HKS throttlebody elbow
Turbo & Exhaust:
• Frank 5
• Unknown brand 2.5" tubular o2 housing
• 2G ported exhaust manifold
• Tial 40MM wastegate
• Buschur 2.5" exhaust with gold HKS Hi-Power muffler
Cooling:
• Modified 240sx aluminum radiator pushed into the support
• Aftermarket cooling fans of unknown origin
Interior:
• 1g Eclipse steering wheel
• Custom radio bezel gauge pod
• Autometer Boost, fuel and oil pressure gauges
• Custom numbered floor mats
• Tech Edge wideband with display in OEM clock location
• 2g shifter and leather boot
• Canadian seat belts
• 89 underdash
Exterior:
• Resprayed glass out OEM Nile Black with slightly more flake added
• Gas door deleted and filler neck relocated to the trunk, but still uses the stock tank
• Antenna deleted
• JDM headlight housings disassembled, painted black and reassembled
• JDM clear corner markers
EMS, Logging & Electronics:
• ECMlink V3
• NGK plug wires
• 2g MAF
• Playstation 2 (Yep, that's right, with Midnight Club in it)
• Fold out screen in headunit and screen in back of center console with plug extenders so the rear passengers can play
• Apex'i turbo timer
• Battery relocated to trunk
Drivetrain:
• Shep Stage III transmission
• Speed Design 4 spider center differential
• ACT 2600
• ACT flywheel
• AWS removed
• 4 bolt rear end
• 5 lug conversion
Brakes, Wheels & Suspension:
• BC coilovers
• Tuner lug nuts
• OZ Pegasus wheels - 17x9 ET35 all around, 5mm spacers in the rear
• Dunlop Direzza ZII Star Spec - 235/40/17
• 2g front calipers
• AEM 2-piece "Big Brake" 2g front rotor kit with caliper relocation brackets
• Stainless brake lines all around
• ABS removed
• Cusco strut bars front and rear
• Whiteline sway bars front and rear
