bov whistling
14u2nV
Agency/St. Joe, MO
My Bov has started whistling pretty loud at idle. I have maft/blow-through, vented to air and it is a crushed stock. When I reach down to the outlet, it is blowing air out pretty steady, and whistling loud enough to annoy. Is this a bad bov? What else could it be? Vac is good, pulled the line off the bov and checked for suction.
14u2nV
Agency/St. Joe, MO
Quoting Barnes:
Does it still blow air out when you have the BOV line disconnected?
a little, but not much.
Yeah, I was affraid that meant it was going. Guess I'll look for a new one.
Nabeel
K.S.A
I had similar problem before. I had broken silicone hose. Check the boost if not boosting means leak, If much boost then your turbo actuator or wast gate is not working for some reason.
