BOV Vacuum Source Location
Chad989of2000
Livermore, CA
Where are you guys running your BOV vacuum source from? I have a 1G BOV and an external wastegate. The reason I bring this up is that I also am running a HKS EVC EZ (EBC) and the unit needs an uninterrupted vacuum source, so I'm using the port right on the intake mani immediately following the TB. This is where I originally had my BOV hooked up to. Can I tee into this line or is there another good source for the BOV?
AllanL
NV
+1 here for this question...
have a 1G N/A intake.
was planning on putting a hose fitting on the EGR vacuum port currently plugged with an Allen bolt.
currently have the egr block off plate as emissions is not an issue.
thanks.
mikus
Aurora IL
Ideal scenario is a unique line for all of BOV, FPR, Brake, PCV, gauge.
- PCV is generally no good to tap for anything.
- BOV is an experiment - some tap no problems, others re, each car varies. Keep it off your brake line though.
- FPR and Brake are both safety risks, but also are closed system... I wouldn't mess with brakes at all.
You can see why having that one extra line is a big deal. When intake manifolds can be had for cheap/free, and are easy to change, I see no reason to compromise on this...
Chad989of2000
Livermore, CA
FYI I do have the intake mani with the vacuum port...just using it for the EBC. So I'll just stick with the BOV t'd with the ebc and intake mani then.
belize1334
Bozeman, MT
The BOV should always have it's own dedicated line. The reason is that the BOV diaphragm physically moves when activated so it's not just a signal port. It's actually moving air through that hose. That's why it's a 3/8" hose instead of 1/4" like the rest of the systems. You don't want the demands of the BOV to influence the signal on your fpr or EBC lines.
I personally run the brake, bov, afpr, VPC, CCV all off of their own signal lines. The all have dedicated ports off of the intake manifold. Then I run my EBC and boost-gauge off of the p-port on the throttle-body.
Chad989of2000
Livermore, CA
^^^Do you have a pic of your setup? So your EBC and boost gauge have a shared line? I currently am running my boost gauge off of the P Port.
