Body Description Model Class 4g63
Nabeel
K.S.A
As per Forum from 4GTuners. Good to know. You may need it one day.
Body Description Model Class "Vehicle
Name
Code" PNC Part Name "Mitsubishi
Part Number" Part Specification "Front Ring
Gear N" "Ring Gear
P/N" Dates Note1 "Rear
Diff
Ratio" "Diff
Type" R&P Rear Gear Kit P/N
EVO1 2.0DOHC/MPI/AWD CD9A SNGF (GSR) 403 21060A M/T & Transfer Assy MD971898 W5M33-2-WQGE N=64T MD743362 92101 to 93113 Standard front diff 3.909 Clutch LSD MB860149
EVO1 2.0DOHC/MPI/AWD CD9A SNGF (GSR) 403 21060A M/T & Transfer Assy MD971899 W5M33-2-WQWE N=64T MD743363 92101 to 93113 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
EVO1 2.0DOHC/MPI/AWD CD9A SNDF (RS) 403 21060A M/T & Transfer Assy MD971900 W5M33-2-WQYE N=64T MD743362 92101 to 93113 Standard front diff 3.909 Clutch LSD MB860149
EVO1 2.0DOHC/MPI/AWD CD9A SNDF (RS) 403 21060A M/T & Transfer Assy MD971901 W5M33-2-WQFE N=64T MD743363 92101 to 93113 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNGF (GSR) 403 21010A M/T Sub Assy MD973695 W5M33-2-WPGE N=64T MD743362 94031 to 94083 Standard front diff 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNGF (GSR) 403 21010A M/T Sub Assy MD973696 W5M33-2-WPWE N=64T MD743363 94031 to 94083 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNDF (RS) 403 21010A M/T Sub Assy MD973697 W5M33-2-WPYE N=64T MD743362 94031 to 94083 Standard front diff 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNDF (RS) 403 21010A M/T Sub Assy MD973698 W5M33-2-WPFE N=64T MD743363 94031 to 94083 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNGF (GSR) 403 21010A M/T Sub Assy MD974291 W5M33-2-UPGE N=63T MD744332 94091 to 95083 Standard front diff 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNGF (GSR) 403 21010A M/T Sub Assy MD974292 W5M33-2-UPWE N=63T MD744333 94091 to 95083 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNDF (RS) 403 21010A M/T Sub Assy MD974293 W5M33-2-UPYE N=63T MD744332 94091 to 95083 Standard front diff 3.909 Clutch LSD MB860149
EVO2 & 3 2.0DOHC/MPI/AWD CE9A SNDF (RS) 403 21010A M/T Sub Assy MD974294 W5M33-2-UPFE N=63T MD744333 94091 to 95083 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995445 KM225-1-PH N=58T MD726425 88021 to 89023 Standard front diff 3.545 Clutch LSD MB185307
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995571 W5M33-2-NPGH N=58T MD726425 89031 to 89093 Standard front diff 3.545 Clutch LSD MB185307
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995570 W5M33-2-WPGH N=64T MD733279 89031 to 89093 Standard front diff 3.909 Clutch LSD MB185313
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995598 W5M33-2-WQGK N=64T MD733279 89101 to 90073 Standard front diff 3.909 Clutch LSD MB185313
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995620 W5M33-2-WQWK N=64T MD737530 89101 to 90073 Front LSD Limited Slip Differential 3.909 Clutch LSD MB185313
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995730 W5M33-2-WQYK N=64T MD733279 90081 to 92033 Standard front diff 3.909 Clutch LSD MB860149
Galant Evo RS 2.0DOHC/MPI/AWD E38A SNPF4 500 21060A M/T & Transfer Assy MD995731 W5M33-2-WQFK N=64T MD737530 90081 to 92033 Front LSD Limited Slip Differential 3.909 Clutch LSD MB860149
US spec TEL, 90 -> _w5m332np__, e.g. kw5m332npzs (unk casing #);
_w5m332npzs, mh8095
US spec TEL, 91 -> _w5m332np__, e.g. kw5m332npxv (unk casing #
US spec GVR4, 91 -> _w5m332nq__, e.g. _w5m332nqbm, kx9091
JDM (Aus) GVR4, type unk -> _w5m332nq__, e.g. _w5m332nqzk (unk casing#)
JDM (Aus) GVR4, 91 -> _w5m332nq__, e.g. _w5m332nqzk, Lh6282
JDM GVR4, year unk -> _w5m332nq__, e.g. _w5m332nqzk, ma6822
JDM (Aus) GVR4 Evo, year unk -> c51ph, e.g. c51ph, ?x9766
JDM GVR4, year unk -> c51ph, e.g. c51ph, hL4285; c51ph, sd7177
unk spec GVR4 RS, year unk -> _w5m332wq__, e.g. _w5m332wqge, qn6866;
unk origin (E39 VR4 written on it) -> _w5m332nr__, e.g._w5m332nrxc, ex6172
JDM ZR4, 89 -> c51ph, e.g. c51ph, hk9717
JDM ZR4, 88 -> c51ph, e.g. c51ph, cL0845
US TEL 1G 3/89 - 6/90 (shift link) -> w5m332npzs
US TEL 1G 6/90 - 2/94 -> w5m332npxv
US TEL 2G 3/94 - 6/96 -> w5m332npzt
US TEL 2G 7/96 and up -> w5m332muzt
US spec GVR4 to 4/92 -> w5m332nqbk
US spec GVR4 5/92 and up -> w5m332nqbm
US Galant GSX AWD non-turbo 6/89-5/90 -> w5m312vqzh
US Galant GSX AWD non-turbo 6/90-5/92 -> w5m312vqbk
US Expo 1G AWD -> w5m33_mn__??? (Anyone know?)
US Expo-LRV 2.4 AWD non-turbo 5spd -> w5m332nnxl
US Expo 2.4 AWD non-turbo 6/92-2/94 -> w5m332nnxl
US Expo 2.4 AWD non-turbo 5/91-5/92 -> w5m332nnxz
ctm
Thanks Nabeel! I compiled most of the info in the last paragraph. The rest are valuable reference data.
Mods, plz strongly consider to archive. TIA!
RedTwo
New Zealand
Quoting Nabeel:
Maybe I've misunderstood this list but I have definitely got a KM225-0-PH (or is it -1-?)
