Body Cladding Removal
einstein
Active member
bountiful utah
Is the body cladding on the vr4 bolted on or is it done with double sided tape?
I saw a couple screws on the rockers but was just wondering, I want to remove mine and spray it with some rust preventer paint because there is alot of salt in utah? Also is there any areas specifically that rust out that i should adress too?
Thanks
Matt
fuel
Toronto, ON, Canada
they have clips, just make sure you pull hard and be careful when prying it off. Some will most likely break when you pull it off. Use foam double sided tape along with the remaining clips to put them back on.
