Blake Adams' 1992 Galant VR-4 50/1000
badams
KC, MO
Owner: Blake Adams
Message Board Name: badams
Year: 1992
Number: 50/1000
Best 1/4 mile time: N/A
Dyno: N/A
Build thread: 50/1000
Motor:
• 6 bolt stock block
• Stock cams
• Gates timing belt
• Gates accessory belts
• OEM Mitsubishi hydraulic tensioner
• New water pump and timing components (Gates)
• NGK BR7EIX plugs
• Custom billet aluminum Galant VR-4 oil cap by Jason Everts
Fuel:
• Walbro 255 fuel pump
• Aeromotive A1000 AFPR (set @ 43.5 PSI BFP)
• Deatschwerks fuel pump hardwire kit
• -6 AN feed line to rail
• New OEM fuel filter
• FIC 1050cc injectors
Intake & Intercooler:
• ETS bar and plate FMIC 24” x 10” x 3”
• 2.5" intercooler piping
• Custom 2.5" intake pipe
• K&N 2.5" high flow air filter (RU-4950)
Turbo & Exhaust:
• Big 16G turbo
• Ported stock O2 housing
• 2G OEM exhaust manifold
• CMP 2.5" turbo back exhaust
Cooling:
• OEM radiator
• Stant 13lb radiator cap
• Stant 180* T-stat
• Factory puller main fan
• Factory pusher A/C fan
Interior:
• Personal steering wheel and shift knob combo
• Paulo fiberglass dual gauge pod
• VDO gauges (volt, boost)
• Turboflanagan custom floor mats
• CDA-9856
EMS, Logging & Electronics:
• ECMlink V3 full (tuned on speed density)
• Innovate LC-2 wideband
• Omni Power 4 bar MAP sensor
• GM IAT
• NGK plug wires
• ECMlink boost control setup
Drivetrain:
• Stock transmission (Red Line MT-90)
• B2B 3 bolt non-LSD rear (Red Line Heavy ShockProof)
• 23 spline transfer case (Red Line Heavy ShockProof)
• EHmotorsports short shifter
• ACT 2100 pressure plate (MB010)
• ACT Sprung 6-Puck Race Disc (6224704)
• Competition Clutch lightweight steel flywheel
• OEM release bearing
• FTP stainless steel braided clutch line
Brakes, Wheels & Suspension:
• BC BR series coilovers
• Cusco front and rear strutbars
• Tuner lug nuts
• BBS wheels * 16x7 * 4x114.3 * Offset 44
• Dunlop Direzza DZ102 tires 215/50 R16
• 2 pot GVR-4 front calipers
• JMF aluminum brake fluid reservoir cap
• Stoptech slotted front & rear rotors
• Akebono brake pads
• Techna-fit brake lines on all 4 corners
0XVLwfhBDa55h8bfgZasSITyD2Zy4Qa0_9-iDrXF3WKnVZEEzSajhdvyE5HpQOBAOcn8fdnSxTvDprHr7ELyWrf7SmQOfXPkxBMLDxw8dHWtQZW6bTThSzg7SepkJMnS_yi1e2097erVOVrpfc1BTecBa7Vos1MP3N4RZji1cb2WsNdXRaj7IwHTIuMl6dWOY-jm4Vu6PQ4Of-mNwawEHq8JVd0sxi6dD19R58ylSPKlBfvkN1urXRDOJBpBp_UGLhxI95NMgnimsw0Y54hEPDsDFPLDb39hgGp2diHhaYLl5BUEzn5p7qqVHHOm1pMWZjc_v6Q66Bvns4SUo69mthE58MR2-7LsuL-ss68uSe0t0uDuj8-j3M_hoZ0cUAaHo8vOR_sktu4FpwQ2m25apVxV6QEjZaKm_W7XevfeyUqiSCpn6AYyugK4SsqvZGq4RDEnhCrmnsGIIm9OL4Vr3unX6GbOMEUUpej51tpHlcbOaEZRSNgqRrIDfNf14wzL3YM-LbU9AWuefnF-xSPXnqHGxaOOeFe4ziXi62wnrg4caT4D1mVJdwSa_eNdoKh3VDTgzgtf5swAv64sLZPNDX-MIVJr9t_8=w1186-h667-no
Vd-OPtM_vCU0JCWgTE2dIudKgu_7j9PQ1-UFQCEuDZ6fnDGKwGMHZBKzzJajqFNaLxxTF4Hh7-HwOVh9m_QPf2CxHlTNDnCtNoBteEwDSDU4mA7dyJbHjq2G-tIzHGzuSwh1SZK0mfiljnWmVRenm-N_AkwazwUMUMcDvrGkmqxiU-hvqry_O6ZNUzxrwmKumCOcsgi756GnptBCyQ27FGrkGHiYx65tMxDO-64v5OQ9XpcFJYmr9QfqPx1xzgM2XD8esn_ICcXhfm7gBJrCAGoexBTq_wnZwaAV0pqfS_OuCbZE0WNhKURej_gun0cFYaXz5y8MEOimspqYCvj830N7utL9TpPR3X5VTfUrysgMd79no_m_mtm2lgwnHiD8ircHzEtpfsHXPyX1mHNA6eTSaX_sWeEkMJ8exj8H8xEE5-gQTp68l_kP68hwfETzygt3TQIOy93pvb453uHBqT6l9wvJAZEi9ULyBa_XTbA1bp5KS7jmCRi7ZixXQzIs-PEf_X-CeoYBAsG1VnpjFl6Y3HGYm4tO4qtusXSoEE0wzwuK8p5b8jGkFGeRBQ_XrqKBWH2mh-Uiv4nZLx7xXZcKag486Nw2=w1186-h667-no
jIvV8Sfe7yrPQx6WE1kjtMuD4KIHirkI-4UlbaU7dqZ2drLLTSAiC7ojkE_fZ-6E3XkvTfqfQo1swdpVrDylXAZZUR0pEw0rXL-D_UE2YzjoE451ablGWQIU7VZoChm-Vfc1_9eL5TzAMZbOaFrvtB15ogzg0XWGuBCl3CFxm4cbGHn4tE1-7U_vnUa8JbYSyz0sLL1Me9GFMWkSwomDG_Vo_b8Ua4AVRiDzoPlAuCNmwiuSgayo1CZ-IBCz43C8Dffn9mFAiD0ChO1wdn3p4pCOSz6xSaAvBAmLj6AypvpoxJOwDqUPQrboTRd2ElzdgMn6D52tk3u94HoQ1577yCjS-boG3rggh0qlPdc4rDt6irqpYk8BbHYg2znK9_xWH153FLfWuCNO9F4NI7XmUUqdfFywEFL4HT4QBKoOpGW8Gvd-_gY3_ffLn6gTheCkhIDjdI7iWmUiUFaN3gCxRhUP9I9w5mhTFCaSSrWrBwS0NOBRjYqVeIYMD3f7axfK_nDuflRvk3OqMigXr6IVQuSb8UwNYaDS5HceWuwS3Eh0rgco7Z5H9cldHbFJgZgmheL1Hz8y-9vARCndTM_phjS6euZuNQ2X=w1098-h667-no
fcpivz9KejNM7c0yKT47ck-yiPHM2leQjZD-AYpevEloQzE802032StKD-r0CPEtSYCryHNhzHuG_E6pmoL5RZGmSnIP5hrDqZcfweGjLuPtRMi38xdXLz58XKmx2GiKWQ7xRLOkfyp34PIMcePrV5lDa76alxPt4N7KSjaoPoXDUSWGpE9IP_6COqPQbrsREg-m9I8TkPixcI3HBwLa_HivRDlX1gHbhHsQlEctSPNxBRsVq43aQt8Rb4S3pajlFiz-8rPDiWwk77CEg2GXue_emOa5IltuWiBfNpJGN72o0oJVuKyVrtEaCD402JzjM_I4Jw8M8Lth7_cjKiInkqZS0VMtcuQuULcaslbEKsqgnmao7XNIwgA95ZmowNxjQ4CQQmp7B13g6FyCaheMAF5FZfCeaRKqz8BCRhAGp8rpY1QYT7-j8M1bi0KFtEe-_LXL7Kh0CTEswKqkw8n0lOxKu7gYYjcKVfhNfCY2THT010WhY2CSfJLnkQOnyAtRvoMqBzbb6R6pTZrEy1f__uak9NrJg0dp8zC5iKNPMeXjCIPWdZlpUMtmUAZAAn0yENjWvF4Kcs3AWWYYD0X-lGshCiq9nM0W=w1186-h667-no
Xu3DnOsElun83KD1C1ZhUOfL899jXhNh1THm9yQNUcwYf9mYRQ6Bq6O4CJuaq0B2bOn__FO0NheWHLGCDyTOI95BPMGZUA4q5JC9BrYmzWJLBP78Ax0H3TDoXiEOrsa33JqNeoisjRbhglIhYc-5lMj8BHsMz0u7J0B6Gy1B9VB8tiqGgaumYLkW3gwR7Rvk9Ze21M0OeRNOq8PR_grSPp9hpzphS611HMPOU4dwo-mSO1sOx4hQFgCcpDa4isTsAeEimIcoaec3B7Rq8A4kCGsYQLig1svpJS15cQlh6zICZPCqvrK5BqZHypl7hPwItnrq4qMJ9L6YceHw-U3RFh0lsQxzE1oQWmXQNRk9rT4B-_wFBAi1zcN-enp3RYCFcgMoBQXWu3g2daPtpShDWFAtaYrEko1atNWtEHllkDvOAQ2eK3j78ODI2oWn-Cm6sJGV6nuEBOxs7sH8Oj0EjzR3xHDWAuP1JE8Wk88TQttPuujff8qG-j7HjOezm3VwdIGRYWqxcl7vt9iFWBx7EeGkdItEiktAP5g1nCPxIFQqBZiGiEzyYo2aR6lUAt2mb_x3l0MijsTLq-8p8SL39XN-LiSF_VPu=w1186-h667-no
Jg5alm1jkZkazCoS6auVd6IU71FnrA6k8n9lw7xuXdx0J3kjt-U_pTSy_nZdIjOGtK3ujh7I6KT6SdmVdiBAC_sL7fJgldCh4OdQAz_URA4JroamypVAlIV_FWTO9zKWJQcZ7G9F1uR3ZAJHsMmdd6ZMkz0WbRz2O-I0thUwENRkfytkvnI3wzmY3kQR1SJN1NbZ06Rerv9txu-T2Q1GK9QybLnVkE7kPM2ziP5AXd2QSvJ1uh_tnd7njqu0NxSA89JRt_JrJUiUARZzN-Gwv_L5AwWpSQZ2J4V1zkLXdhNRJyET7XEA1_tqMg6UhfDc-1TLnhmQW593SpckXGvYoW8zIvFj2yvttAptXyLwmZ9iPCcJMYMfCdJwDrq-CmTLtSwkSgr2ojEeOf95FxphDhULgSbO2Og7McCaUWChSjUqY5vNgPxQihJj0KItLlTbbPyMP5gPLjLZTLiHZCem6g6CXyqF6Hd7MBNb9KHp9up6PdFozgyAYWcsENL5Ne6RnY0fU_96Xxqpxik5XXFa372tMl519uom0fFp1ris6fbu7FyO1sCT5ncvULuBRiSXicngT4YD2p3oEmamUpj9Fc4Uct7foCHn=w1186-h667-no
9idlsiPwTf1xkRd58CskJ4PttoW9meW5f4ruLb6M6kjaszX2XHE8yHKk_xRKyzwNvwjqEGomDEPK6hPQcdk1_aRD9guISglgt9dPV1EDSLtxACtsphTCdzxAstM7jG9hLYCQB-rJA4Dk1Zd6vw3bziHdRkgyU9wW_Ke0uUqnUtBlHEyIj_ZZMdIPrOgqueMnk-5m7qNXotP85BEtBOkwnQMauSN5F_vO2pT5hNwAJzdJetL-Si84Chi50KhBeWESQl3i_NCYN9pdLT0W2EHyjMOcTtarkAJYZ4cpp12Q9JTtU4F4HO7xEewsNOAM0CcIgfZdmD28HzZpU7eN-DznrVyP73mjCM5DVXiWkEm_OnFkT4u_EZJphALGyrJZvKj-F-N4hePauKHGJKB1Nf73NUh2a2eQfSgYDOh7Re4awhgX1FZ3aq2n4R9yxlFBD4HQ7sPYrTld6YnGevwb50MR1gX9QRWTsdhBCZS_L-mEsFwdebk3yjmVlVK84t7796qgc25a7AE_b5dKDJNdqIj5KucrX2xR06xbNyoM2MQzK4wyVbChUql8_yZy2VrnS1DZ3IxwRLm7kQZ7XeTvFDG1XF8UiMjJAxS0=w1186-h667-no
YtZuu49NsCUJw1mUbDurkIgbW8hxUx3e82VMYU72yp8O-pzclN5h8b-azwrkjW9sLbEMVxWp2psNfRd-nfI2IbaAbcuo4JFhVa6XbHTJmIbybQ7L31mk_MhMicCOWqaxiZu3KBG4wO2NDodb2wPOvKtil05vJAGNpyVpGDdFvVON6MxGD_c_-VA7orKJU9VqrveaButfZ8MgH5eRDfteEYEmzwT9aGO8HTUvuxD6Gsh3DWQ60M4fEMJNAHeALakGXSBdUOi23RyOs0FZOfJ4f6nLDuCi_1AuKD11AaNyAYjQcwNpQUgiUtQ39_oyhAvvi_NtvsHvz0NaNG5PxUOQYjBJQkyWBHnLszHOn9Z3JTt_I0u1sEwDMrKaXlDKBzgvJeggSAgkaD_WpQpzolWIBclgjI4OKz7z6BSC4cJGTwHkMZGuB1Bxm-4PbCdmTObFWsE6J5lQotHHXXaE1LaYWovtsIiAPlMfNyuyapMzlmdFQtHIBLwydpoDQeLY3pkY2mDKpHvEDLas4A9BZNbHbM_mBHmiwT66XIWtWK05WEYKvuLglOtejVDV66n8yo5gd9OhAlIYgcKG75Rk8n7LINH7ROZSf5Yu=w1186-h667-no
2EF73pi24SN6muhpOXhtF2AXOYb3kHypO76tAQQQjvE6QVGWivl0kGiHrMtA-ORuohVgPPRgMckH0WNv8MYB22PHh_t5dbRMWW4CQXDoGJy_j1x5pPOU4WNYm8kIIPr9-6d5Nrlk7Jv18Q-oxPLcJaRYILs2HwVerST6s6snqfXfePa3xwfGe9MDoBgwbwFd5M5l_x2RrcOcsv4KpBnTBizbZKTEZX3wJbcAQz2gLZSKffoRdmFd9YhG5fLLgT36IqaZ_sguqCC_NkL-BszuKGN1_IaUVakfROnR3RQn8AtZJeCeXDLF8-BIzTzMahvF_DHxnbmxxP-55Kh0q5ltYPf6Fy4q65VCpb2JuxaRJA-bs7J4at_hr4jUPMSRZrvRZTknaKIlt1MDF2AU3KlLUR4Rm8g79Zemu5EU4qGMzSdmlWKNmmbeBDd0LExkM7Y3ZEUvNXVyo4gS4AR9cIAsBlXI1D9n2mQN-yg6VsgOUMqeHCqB8CQ1B484ajthnmtX1oNmHzRT2b-_yQsCmGfcnnqNyfGEun_vwFkpn5IylEqI4G-tQfeO8ez8dMtd4qP2q9rcsgtfYlG04nTJSSJZPjy3IDYPWbVp=w1186-h667-no
3mjch_hkG_vt0VITzJ-puLQ0wjLd0VF4wzkEoRbyy2L1QS88Zw-KqlEt084Pwzy58CE6ZSobB22TZRU_fcAKo6uAZBVSCAbeIt1rx6fmW9ndS5RrwfuP9zZ4AD22xURKE5vncprv4vDXPV_cTO9cyVtsjQQ2J6yfevTqxqCWZ_TeFopTAWNnRAL6ARdhCp8A9585o2JVsh2EVfeQ2-oKBCTrYKj5c2zdwbaOnQRCmmEqRgO8ZHHVYLFENauuFsWb4LUrWxjlhsaWImFDF0aqdIEdiNKOdLE1ClkCdiZoucCybwoHrGTmjI0aY94EEqo2yJiCiua5rGsWVkMDaCEfdFuNrmHYPZJAz0gga9ktlpLaQLS9f_UwOVixoJdCfkB05vCem7KtR3Rw-Qf1lcJh4F4arfCibcvTTDTliEX66ZouN1Z3aHeC2GATbLI7cYQK-znX_G5BCjEX602xqduzlAFYDtvr8t7oRKzdRCtsJFS7crNk0ymXICkGmHU0hEcShVCsP_oIZxi1SBcB8dCsq01Kdi0iYybnx90TXU3J0RShqOZrs9s7mZLn4T18M-1PA5mpVg_GoBmqU6oY1g6BnNLN96V3xzyjn_Hq4Zm4QcDJjH8yBmWzflE8FyXvXrMPviDuXB9T1vobgv_uZrqUny1gZXECzy0o=w883-h662-no
TWNCCRUey3shOXT666YDZLRzSbAylkOg3pITZR91AxgJEn2I_FHxaSgfUhQ8dkrfwGH3j-DPGRd6vXUygez4Zq8ZdxsEMdB3p3tFPS96PiJd5pQ-EVOvroxcOytZ_trN1nmoScDVGtaJXNefknwWADPJI_7_-hgEBDMLe7jjtZcqVsTHGOWrxPDSMN68eVXf44wavRV-S7sVeCLS0P3r1tueRlhNCEkvtQ8BBB3O-f-7IhnGvJH_OS-Y8F1ciuzax1ip7tpXh0O9UBHLxDGq2LExTInbR0dB10AOmiJI0qWb0frGO8Ao6gQQ8MhuP1JN8ncSv_-IZtKMxyPs8blNRjwWwCIVXqExDwO_K682Y99SRKxnq_nTaxaX9VoW7B06-gYiCZZafrXcgUeePNVPq5il3_w7OUdHHDyboYlZAjZHttEY8EYjwQaIcjKxquaWW-B9fb-l19aOxxlXo10haKsUHJwqCuYASe8ipQ9IgJQZUhOLrNuZr0AIrGkR56jXZ2wpReclHcoI7MkcoeCNlwyb602WETidbey486oRY3EANNk8cF88D15S8Pgk_c4coa1PPku3CXDGtlPs3OF3apG23nu3ovtn2apdWgo=w883-h662-no
XkCydMkdnpHA4hggMfrT2yxh7gkeF7Mk1aQstUxQlsUr5LUOxLeTasCKLxvYZkuSm_vKRzA4-QXhXMC6lhnS9nP4elTPhb1H160CKtb9r_Cu-buRykIr3oNpYIq4c5k9S0ynnBmB7RcjRlWegKutTMZ-Vg2ed3fnI0hXiYu8lig3-Zu7P9IMe_CDT8NlPkDyALChqWav2ZKIx0uBr7IiNU30r5eagWEtqbynEDmPJNQVTlOo2mncG8LUIvZlrtmMO1Ls0YwmlS7VixCzoCoCQztpAr-851UDtCr3CPZTO0smpx9POekhC0VKi6UJ4FmVZSPVYGM3BEdHgq5IrzmHxmrPii_4vQVt0cT528H2Od_Ru4vO1sO6L8rdbTtcIuc-oso7OvxDRVK6YQVflSgveWNdszEizvUL5_3_G8tRyrm-7ik7_QB6cWypEnrKfhLRuB6lyEXdsYjsDy3NiucIGOpGmcymeedLRA9KL1RRAOr-M_RxM-aHly3FmYo_w5Ih5dFLJSwNOBHOZT-EyUNc7Mahmdiv7LM7-_3ap639VLGrx-dzLIDGiRdhYa9LSdXQoCRabusZNiDxvn46PofbN3vMfsDQI8fhivgYmAVbnvtrgmRN1luTIF9jAade2YMpQ9BmQdd1WKvwWiRUtXVNsUW8BJQJj06VWtEbN6f0ojxKRKw=w1177-h662-no
