BISS screw gone.....
rdomeck
Indianapolis, In.
I knew it needed a new o-ring. I had to reset about every 1000 miles. Well it really loosened up on a couple hundred mile road trip yesterday and now I need a replacement. I have found a standard Galant in the local pull a part. Will a non turbo biss screw work?
Thanks
citymunky
Chesapeake, VA
I don't why it wouldn't. Also you can Advance Auto Parts or whatever for the o-ring, they should have a box to metric single package o-rings.
donniekak
surprise az
Almost all of the 90's mitsu biss's are the same. Some are plastic, and some are metal, but they interchange.
rdomeck
Indianapolis, In.
I would imagine that would either go in well and stay there making it a bitch to remove later, or go in easy and blow out at the first sign of boost pressure?
Wizardawd
Franklin, NC
Quoting PreskitVR4:
You should carry a plastic valvestem cap around in your glovebox. It is the perfect size.
Why carry it in your glovebox? I have 4 on my rims.
And I think he means it as being a emergency hole filler if the BISS pops out. So your car isn't screaming at 4-5k rpm all the time. Stay out of boost until you limp home type of thing.
Wiz
