Back in the Game!
Terrance362
Winston-Salem, NC
Getting to the end of the build and I am at a stand still. Well the car is drag only and weight is a big issuse now. I am in the process of going auto, I understand that the conversion adds weight but it also add a low percentage of breaking things. Now down to my question what do you guys think of liquid to air over air to air? I know that with liquid to air you have to run lines and a pump but its keeps the temps down. Air to air is good but cores can get a little crazy. Someone please shead some light on this. All comments are welcome
91bgvr4
Member
columbus,in
^^^^agreed But some peoples perception of the word "drag car" differ's, that is why i ask how intense he is going to get
Terrance362
Winston-Salem, NC
The car is drag only. Cage,slicks,spray. True it might run better but weight wise and less moving parts. Air to air is less moving parts. Water to air has a heat exchanger,water pump,tank,lines. Now throw the extra weight of a Auto setup
EMX5636
Bucks County, PA
Run it on methanol. Sell off the spray and don't run any IC. Lots of money into a fuel system though.
If you are worried about complexity, stay A/A, but an A/W is better for a strip only car. The weight is barely an issue. Pump only a couple lbs. The intercooler weighs less than a big, efficient A/A, and the exchanger probably evens it out.
