AWD Summit tranny parts in GVR4
Hey, I just disambled my JDM GVR4 tranny. The 1st/2nd gear had hard time engaging(The first was just grinding and not engaging at all). Btw I did the cables adjustement and AC Delco Fluid and did not work.
I have a AWD Manual Summit tranny under my hand. First sight it look just the same.
Can I put the 1st/2nd gears assembly into the JDM GVR4 tranny??
Do I have to put both 1st/2nd AND 3th/4th gear assembly to make sure the gears will fit togheter??
thanks
random image of Gear assembly /ubbthreads/images/graemlins/grin.gif:
Been told that the Baladeurs(don't know the english word for that:p...The parts that slip up and down)are gone also on the gear assembly....
I could just slap the Summit assembly in...
brisvr4
brisbane australia
That would be the hub and sliders.
Perhaps you might be better off talking to one of the gearbox guys over there like Jacks, Shep, Tmz etc?
Leon_R
Chelmsford, MA
What year is the Summit tranny?
If it is 92, it will bolt-in. If it is 93-96, you will need to follow 2G tranny in a 1G VFAQ.
If you want to use Summit tranny guts, remember that Summit has smaller viscous coupling and a matching center diff cover. So I wouldn't use those parts. But you should be able to swap in gear set (not just one shaft).
Also, if swapping synchros was trevial, Shep wouldn't be driving around in a 9 second GTR /ubbthreads/images/graemlins/wink.gif
There is a code on the summit tranny:
B0T 4131 NPXV
It's harder than expected...Ive been told by a tranny guy to keep the shims and all the gears from the same tranny to make sure the tranny won't make noise and will last more than 1 week...lol
So I decided to use all the gears from the Summit in the summit casings except for the front Diff(to keep same gear ratio F/R and LSD) BUT the front summit diff have smaller diameter and so the diff casing is a bit smaller and the GVR4 front diff don't fit into the summit Casing!!!
Leon_R
Chelmsford, MA
Any idea on the year of Summit tranny?
Keeping the same shims is better than nothing, but you really should properly shim the bearings!
