Auto trans cable plate
tektic
ronkonkoma, ny
The auto trans cable is run through a hole in the floor. There is a bracket held up with three bolts which has a gromit that the cable passes through. Is there a similar plate held on by 3 bolts approximately 18" behind the front subframe on the floor pan of a manual car? If I cant get a stock piece to cover this i have to make something today before I install my drive shaft and transfer case.
