Anyone using ebay cam gears?
MX4
New Zealand
So I'm probably going to get rinsed out for asking this question. But does anyone use, or have any feedback, on using the cam gears available off Ebay? I am considering picking up a set. Otherwise I might try and track down a second hand set of better quality ones.
Heres a link to some I saw - click
I would look into what its made out of dont want the teeth to sheer off.
JNR
ca
I wouldn't trust chinese junk on something critical like cam timing (well I wouldn't buy it for anything, but if I was forced to choose that is one area I certainly wouldn't skimp)...the "real" ones aren't all that much, are they?
460GVR4
tacoma, wa
I asked myself the same question and what I had found from other forums even outside dsm's, is that the design of teeth on gears is not quite up to snuff and it wears your belt much faster than that of higher quality and design products. You also have to imagine how much time and effort was put into the gears if they can sell them $60 and make profit.
minneSNOWta
Eagan, MN
When I bought a fully loaded head, it came with Onsoku cam gears off of ebay. The car the head came off made 487whp, but there was no way some cheap sh*t was going to be responsible for thousands of dollars worth of googies. Ended up with Fidanza's instead.
ronnycordova
Muncy, PA
I picked up a set of HKS gears new in the box off ebay awhile back for $150. I just looked though and the guy who was selling them is no longer a member so I'm going to assume he's in some sort of Russian dungeon by now.
boostedinaz
Scottsdale, AZ
My question is...do you really need adjustable cam gears at all?
Do you plan on degreeing a cam on a freshly built engine, or are you going to spend a ton of time on a dyno playing with them? If not save your money.
I always find it hilarious when people spend 200.00 for cam gears that are set at 0.
Leon_R
Chelmsford, MA
1 you do not really need ANY adjustable gears! Some cheap cams come with improperly indexed pin, so they need to be corrected, but that is just another reason to stick to high quality cams!
2. Try wrapping a timing belt around a stock and then Chineese pulleys, you will notice that you will have to force the teeth into the gear after 220* or so (that does not happen with a stock or HKS pulleys). You may say, the actual belt doesn't make a 220* contact with the sprocket (and you would be right), but it shows that they are different! And that mismatch must put more stress on the belt teeth!
If I had to, I would only use pulleys that fit the belt similar to stock pulleys!
