Anyone got a good source for AEM wideband O2 sensors?
DynastyLCD
Harwinton, CT
i figured i'd post this here since it's not quite a technical question. i need to replace the O2 sensor for my AEM wideband. i know these are the same Bosch sensors that quite a few OEM manufacturers (Nissan i know for sure uses them with the same plug as the AEM)
so i'm just testing the waters to see if anyone can get them cheaper than $75, as that seems to be the norm price wise. or if anyone who works at a parts place can do some searching and figure out what this sensor cross references to, and if it can be had for less.
thank you!
Rumor has it that the Bosch 17018 can be used. I don't think it's "pre-calibrated" like the AEM sensor, but I've heard that it will work just the same.
Should be able to get it at autozone or similar with a 1yr warranty for under $65.
I run innovative lc-1, so I'm not positive about this.
