-AN fitting that fits the prop valve?
Looking for an adapter that screws into the prop valve to convert to a -3AN flexible brake line. Can someone tell me if either of these 2 adapters will work? What size and pitch are the prop valve ports? Thanks.
Hey, thanks for the suggestion. I didn't know JNZ offered that kit. I only need a few pieces of it though, so I'll hit them up and see if they can help me out.
You need a 3 AN to 10 x 1.0 mm inverted flare fitting. I know they are made as I used them decades ago to put SS brake lines on my 510.
ade
Paumanok NY
same thread on our calipers, you can throw those fittings on an run lines from the prop right to the calipers
