alternator froze...
so i got my galant running for the first time in about three months, and i drve her to the car wash and gave her a bath and drove back home, so night time comes around so i decide to take her for a little cruise, i notice my stereo turning on and off and then i come to a stop light and my lights dimmer then the car shuts off. "dam i guess i need a new alternator too" can anyone give me some tips to replacing the alternator? havent done this befor on the galant, im still kinda learning. any help would be great, thanx Swanee...
chucklesas
Dayton, OH
It's been a while since I've had a car I needed to do it with, but if memory serves me correct I suggest the following:
DISCONNECT BATTERY first, then Remove Upper IC pipe (not sure you actually have to do this step), unbolt 3 bolts from power steering pump, rotate out of way, remove PS pump bracket (3 bolts, 2 on front one on side) remove alternator (disconnect wire and plug, loosen bolt on tensioner, turn tensioner CCW to release tension on belt, remove long bolt at base of alternator and it should come out with some rocking up and down), Install in reverse. You may have to put the car in gear and rock it back and forth to get the holes on the PS pump to line up with the bolts.
I think that should do it.
Hertz
Chicago, IL
Some people swear by the "lifetime warranty" alternators, but that does not mean quality... It means they will keep replacing it with the same junk. Since you're in Chicago, look up Cano Electric for a quality rebuild.
Replacing the alternator, I usually drain the coolant and pull the radiator out, then pull your intercooler pipe (hotside) should give you enough room to get it out.
If you're in need of a spare I have one ready to go.
thanx alot guys, hertz il take you up on the alternator< what price you thinkin< bc we can meet up whenever. pm me if you like or just leave it here either way try to let me know, thnx again, >Swanee
mikus
Aurora IL
Cano had a save $10 print coupon on their site btw.
(Hope I don't mess up Hertz's sale and get teh BaNZ0rz)
Hertz
Chicago, IL
Er, ah, that wasn't a sale feeler -- I meant that he can borrow mine while his is being rebuilt. I still expect him to go to Cano. /ubbthreads/images/graemlins/smile.gif
