Airflow calculator based on fuel flow and air/fuel ratio (CFM)
This calculator is designed to give the corrected airflow of your engine based on fuel flow and air/fuel ratio. Use the subsequent worksheets to import datalogs, then copy the necessary information to first worksheet. Some Compressor Maps are available in the last worksheet.
Airflow Calculator
steve
NJ
Will move to Info Archive if no one has anything to add in the next 24 hours.
