Air intake setup.....
Ok guys I am getting my t3/t4 on the car. well currently with the stock 14b, i have the hks powerflo intake with the mas hacked inside the canister. now my question is that this will no longer work when i put on the other turbo b/c of the inlet size and that it will interfere with my ic pipe routing. so i have been checkin out some of the pics on the board of harrys car, jons, rob when he had his t3/t4 and also kens. i see that they all basically look like a normal pipe with a k&n ont he end which is cool. but what the hell happens to the mass airflow sensor when you put something like that on? i thought that thing was necessary.
Those guys without the MAS have gone to a VPC piggyback computer, or other MAP based system.
Jeff O.
#1886/2000
VPC would be the easiest way to do it, that's what I have.
You could just make some pipe that goes from the canister to the turbo.
Ot try to use a 2g mas and a dejon pipe.
I believe the older pics of my car on the site, I still had the MAS. The pipe I used was just a three inch pipe. The "MAS" end will be very close to three inch. So just get some 3" coulpers or elbows and a pipe. I may still have mine if you need them.
