AFPR question
Jostar
Chicago,il
Is fuel supposted to come out of the vaccum port??? when i unplug it fuel come out of the vaccum port & as soon as i put it back i think it stops, I think it stops cause as soon as i take it off it's dry then 3 seconds later it starts coming out again..
BoostedAWD91
Danville,Pa
yeah looks like ur regulator is junk, u definatly shouldn't be getting fuel out of the vac port. what kind of regulator are u running?
That is def not supposed to happen. that means you are running fuel either into the fuel solenoid (if you still have that), or you are running fuel right into the intake manifold.
like stated above, the diaphram seems to be FAIL.
Hertz
Chicago, IL
That happened to me in 2001 @ ~145k miles.
Yet another reason why you NEED to have an AFPR if you're modding.
Jostar
Chicago,il
Quoting BoostedAWD91:
It's a Aeromotive fuel pressure regulator... I bought it from a member here a few months ago & i never installed it..
Jostar
Chicago,il
I wonder if they are, It seems to stop when there is vaccum apply to it & as soon as you take the vaccum hose out it takes about 3 seconds for fuel to come out..
GVR4_1057
Brucetown VA
It is probably a small leak. When the vac is on the fuel pressure is lesser so no leak, as the vac decreases the fp rises and it leaks. I have gotten a spring from aeromotive before and they are very easy to deal with in fact I think they sent it free of charge /ubbthreads/images/graemlins/cool.gif. I 'll bet you can purchase a replacement diaphragm. I do not think that would be free though. Let me know what they cost if you can get them.
