AEM uego questions
dsmless
tucson,az
So I installed my aem uego wideband gauge/sensor on 96. I am curios as to the white 5v wire coming off the gauge (red is switched 12v, black is ground, blue is for a serial logging), this white 5v wire. Can I just run it to pin 4 on the ecu which is the factory O2 imput and delete my narrow band O2 sensor? I am running ostrich with the dsmap/werewolf program to tune, I get the o2 CEL code on every time I turn it on, I delete it with the program but kinda a pain to be doing it every time.
So any help pertaining to the install or how too solve this problem is appreciated
alansupra94
Wayne,NJ
No that white wire is your 0-5V signal that you need to feed to your Ostrich setup. I am not 100% what pin it is suppose to go to but you definitely need to hook it up.
I thought DSMAP had an option to stop CEL codes from throwing out permanently?
dsmless
tucson,az
Thats the same schematic I have and its the way I have it.wired too, sucks everytime I start it I.have to delete it again. I will bust out the old trusted buzzer and verify that its actually the o2 troble code. Thanks for the help
