Adjustable Wastegate help!
ExplicitCC
Lake elsinore, CA
Ok guys I just bought a 20G and it didn't have a waste gate, so I bought a adjustable one, how do I install to work properly? and what do I need to do to have it hold more boost? thanks for your help!!! (been looking and searched here but couldn't find anything)
tektic
ronkonkoma, ny
The arm should be adjusted tight enough to hold the gate closed with pressure. Take it around the block and see what it reads with the vacuum lines installed normaly.
If everything opperates properly then you can add a mbc between the wastegate and the presure source and dial that in to sui Your desires.
Don't go too high and blow anything up. That's a real possibility if your not watching real close.
