ACT solid street disk. Minimal feedback on the web. Anyone?
Scott Y
Lakewood, Colorado, USA
I am contemplating a 2900 w/solid street disk. I ran a 2600 + organic disk for over 2 years of 12sec passes plus thousands of street miles. It was a great clutch, but I want to be able to shift faster at over 7K or NLTS to post some low 12s, and I thought that this combo may work for me. No twins, no pucks, I drive my 5 year old daughter around in the car, sometimes it's even the snowmobile (our only awd car).
I need a Jacks Transmission and a clutch this year, just gotta save some more pennies.
464/2K
Denver,Co
I'm going to be running the same setup (2900+unsprung 4puck). Well see how well it hold up.
Brianawd
Portland OR,
Good luck with that. You will be lucky if you can shift at any thing past 6,500rpm and not have the clutch drag.
Run as faraway from ACT as you can.
Scott Y
I've had great luck with the 2600, I could hotlap for 5 or 6 runs for a few test-n-tunes per year plus street playing and it worked like an absolute champ. It shifted pretty well at 7K, but I found a couple of tenths by shifting at 7500 and that's where I found the shifting fighting me. I discovered this at the end of a few years of faithful service, with the clutch fork slowly moving towards the driver's side of the bellhousing in relation to the slave cylinder.
I have no problem getting another ACT clutch, just thought the solid street disk might be lighter than the sprung version and help a bit at higher rpm.
464/2K
Denver,Co
Scott see my thread a few topics down.... That is one of the many reasons why to steer clear. You most likely have an old style act which is why it has held up.
1badgvr4
georgia
Why do people think twin discs are hard to drive? with a 2g slave its nicer to drive than my old 2900 setup by far.
belize1334
Bozeman, MT
An unsprung puck will not drive differently from a sprung puck. What it will do is communicate more driveline noise and will also contribute to faster wear of the transmission input shaft splines. The main reason to prefer unsprung is that ACT disks have a habit of popping springs which will cost you some down-time and the cost of a new disk.
donniekak
surprise az
Not only do the sprung act's pop springs, but i have an unsprung act disk in my garage that stripped the splines off the disk. ACT=garbage
