ABS Light question
xaisomboun
Minnesota
So I was reading around on how people said they made the ABS light go away by pulling a couple of fuses and removing the abs ecu..
Question is, I never knew WHICH fuses to pull... Could someone give me a heads up on what to pull before I make my car explode??
So far what I got from reading, I got the 20a fuse removed next to the battery and took out the abs ecu in the trunk right next to the antenna, what else is there?
mikus
Aurora IL
I never read a definitive answer on this, and just pulled the ABS light in the dash. Takes ~5min, I did it sitting in my car while about to leave work.
SouthCaliVR4
North county San Diego
ABS fuse is in the three fuse holder on the batt pos cable, abs computer is in the trunk by the antenna motor.
If you're going to disable the abs it should be done right. remove the abs pump & change out the front lines/proportioning valve to non abs.
