ABS light on after long storage, new SS brake lines installed
PJGross
Lake Orion, MI
I replaced rear calipers and added SS brake lines all around while car was down.
I bled the entire system and brake pedal was very firm.
Car was down for years, so could be corrosion on rings?
I started up car today and brakes felt normal, but the ABS light is on along with the brake light.
Suggestions? I did do a search but nothing came up.
-PJ G.
G
zompton
Probably air in the abs pump. Try activating the abs on loose gravel and then re-bleed. If it will activate. Not sure if the light being on will disable the abs.
PJGross
Lake Orion, MI
Got a dirt road right by the house. Will try it Saturday.
I just got insurance put back on it today, but can't get to secretary state for a few days to get a new tag.
Thanks for the tip!
-PJ
G
zompton
Let us know if the abs is disabled when the light is on, clean abs hack!
PJGross
Lake Orion, MI
Procedure to bleed the ABS unit itself? Is there a VFAQ for this?
I did not do this. I only bled brakes at the corners.
I don't believe there is a special procedure for bleeding ABS on this car. I use a vacuum bleeder on mine usually, and have not had issues.
I would check for junk (usually metallic) collected on the front sensor magnets. This can affect the reading.
Sitting for a while it may be a stuck solenoid in the unit itself. Clean fluid and driving it to get the system to activate is a good starter approach. Hopefully if this is it, it will break loose.
If you end up needing a hydraulic unit (if you keep ABS), I think I have one in my collection.
PJGross
Lake Orion, MI
My dirt road is bumpy, too! That could help.
I will also see if I can clean the rings. I could have bumped the sensor on one of the corners as well. I changed out the passenger front half shaft when it was JSBing so I can start there after a quick drive on the road.
Need to get my registration updated. Last tag I had was 2008. Saved over a grand in tag costs that way, at least. /ubbthreads/images/graemlins/smile.gif
-PJ
I am planning to use the specific year plate program in Michigan when (if?) I get mine back on the road this year. I have a nice pristine 91 blue plate for it.
slugsgomoo
Tacoma, WA
Delete the ABS IMO. The stuff on our car is 2 channel diagonal garbage, and it barely helps if you brake like a monkey mid corner in the rain. In every context of using brakes properly it simply increases your stopping distance due to the glacial cycle rate.
If I had an Evo, I'd keep ABS, but on these shitpiles, it's a liability. I measured a ~25' shorter stopping distance from 60-0 with some very fast & loose methods, but it was pretty consistent.
The junk is heavy, doesn't work well, and makes the engine bay look like crap. Plus now I have an awesome location for my remote oil filter setup /ubbthreads/images/graemlins/laugh.gif
