Turbo4door1
First off, YES - I searched.
History - started driving my car again on a daily basis, after it has really only been a sunny weekend toy for the past couple years. To give you an idea of how little I drove it, I just changed the oil the other day at 2,989 miles, and it had been TWO years since the change before it. /ubbthreads/images/graemlins/crazy.gif Not good, I know. It sat outside covered for about two months prior to me driving it again. Typical rust build up on the rotors..etc. The ABS light came on shortly after leaving the driveway. Anytime I get on the brakes, the ABS activates anywhere below 5-10mph. Pretty scary when approaching a busy road, and almost rolling through the intersection because of our shitty ABS.
I found posts where a few people had the same problem, but never saw a fix for it. Our ABS sucks, and I really would rather it just quit working all together. What is the absolute MINIMUM I can do to disable it? I really don't care whether the ABS light is on in the gauge cluster or not. In my search, I saw unhooking the ABS computer in the trunk, pulling the 60amp ABS fusible link on the positive battery terminal, and pulling the front most of the three plugs, above the ABS distribution block, on the drivers side of the car. For the short term, if I just pull the 60amp fusible link, will that disable the ABS? Eventually I would like to eliminate it properly.
Thanks.
Thanks.
