#996/1000
unistylef
San Diego, CA
Hello all! I'm quite pleased with my new-to-me 92 Belize Green.
No pics yet, but its in great condition.
Just wanted to say, I understand this is a community. Every member of a community should have something to contrib, so I will state that I am a confident photographer, graphic designer, and webmaster. So, if you need anything, let me know. I'll see what I can accomplish.
[P1=POWER][P2=HANDLING][P3=APPEARANCE][P4=REGULATION COMPLIANCE][P5=REBUILD]
[V=VARIABLE][P=PENDING][T=TRIAL][IP=IN PROGRESS]
CURRENT
STAGE 1: FOCUS: [P1/P5]
#_____| 996/ 1000
TRIM__| 1992 BELIZE GREEN A87
NAME__| [T] KAPPA 996 SSS (Super Street Sedan)
GOAL__| USTREET/ AUTOX/ Track, Higher Powerband, Responsive
COMMON| 30-65MPH, 90-115MPH
POWER_| EXPECTED 350-400AWHP
TURBO_| EVO3 16G @ [V] 20-21PSI+
MOTOR_| 4G63, 272 CAMS
FUEL__| (San Diego: 91 OCT) 550CC
SUSP__| [T] F: EVO8 KYB R: EVO8 BILSTEIN, SWIFT SPRINGS
TIRES_| [V/P] 225/40/R17 SUMMER PERFORMANCE
UPCOMING 2014/2015
STAGE 2: FOCUS: [P2/P3/P4]
FUEL | (SAN DIEGO: 91 OCT) / [P] E85
SUSP | [P2] F/R SWAY BAR
LSD | [P2] QUAIFE
TRANSM| [P5] EVO3 1ST/5TH GEAR
REAR | [P5] 4 BOLT
PAINT | [P/P3] Either: Brit Racing Green or BMW Forest Green, REMAIN DEBADGED
SAFETY| [P4] TUNING SPEC SEATS, 4PT HARNESS, 6pt WELD-IN ROLLCAGE, Fire Extinguisher
UPDATED DETAILED PARTS LIST:
<b>ENGINE</b>
<ul type="square"> MLS HEAD GASKET
ARP HEAD BOLTS
NGK -7 PLUGS @.022 GAP, NGK SPARK WIRES
272/272 CAMS (REGRINDS)
ALUMINUM HALFMOON GASKET
FACTORY OIL FILTER W/ SHELL ROTELLA 15W-40
</ul>
<b>EXHAUST</b>
<ul type="square"> EVO 3 MANIFOLD - CERAMIC COATED, PORTED,
ARP TURBO BOLTS
FULL 3" TURBO BACK: STAINLESS STEEL, MANDREL BENT
3" DOWNPIPE - PAINTED &amp; HEAT WRAPPED
3" MAGNAFLOW CAT
3" MAGNAFLOW MUFFLER: SINGLE TIP </ul>
<b>FUEL</b>
<ul type="square"> WALBRO 255 LPH
AFPR @ 37PSI
EVO 8 INJECTORS 560CC (CURRENT)
860CC (LATER FOR 22+ PSI) </ul>
<b>AIR</b>
<ul type="square"> ETS FMIC (24” x 10” x 3” Bar and Plate core)
2.5” IC PIPING
2G MAF
2G INJEN INTAKE
MANUAL BOOST CONTROLLER </ul>
<b>TURBO</b>
<ul type="square"> 19-20PSI
MHI EVO 3 16G: CERAMIC COATED, PORTED
O2 SENSOR: CERAMIC COATED </ul>
<b>DRIVETRAIN</b>
<ul type="square"> ALUMINUM FLYWHEEL
METAL SHIFTER BASE BUSHINGS
BASE BUSHINGS
JNZ DRIVESHAFT REBUILD KIT
ACT 2600 CLUTCH
CUSTOM 1G SHORT SHIFTER
TRANSMISSION: LUCAS FULL SYNTHETIC 75-90 W/ LUCAS OIL STABILIZER
SOLID TRANNY BUSHINGS
STAINLESS CLUTCH LINE </ul>
<b>SUSPENSION</b>
<ul type="square"> EVO 8 SWIFT LOWERING SPRINGS
FRONT: STRUT BAR, EVO 8 AGX STRUTS
REAR: STRUT BAR, EVO 8 BILSTEIN STRUTS
NEW BALL JOINTS </ul>
<b>WHEELS</b>
<ul type="square"> 5 LUG SWAP: NEW WHEEL BEARINGS &amp; SEALS
EVO9 ENKEI RIMS: 17"X8" 35MM OFFSET
DUNLOP DIREZZA SUMMER PERFORMANCE: 225/40/17 </ul>
<b>BRAKES</b>
<ul type="square"> JNZ ABS DELETE KIT W/ PROP VALVE
SS BRAKE LINES
FRONT: 3000GT ROTORS 313MM, 3000GT CALIPERS 4-PISTON FIXED
REAR: 1G STANDARD </ul>
<b>ELECTRONICS</b>
<ul type="square"> REBUILT ECU
ECM V3
VDO BOOST GAUGE </ul>
<b>OTHER</b>
<ul type="square"> '89 GSX GRILL
'89 UNDERDASH
DSM 1G STEERING WHEEL
JDM HEADLIGHTS: 6k HID
Mint Fogs: Yellow HID
LED Bulbs throughout
BATTERY RELOCATION: FOR 2G INTAKE </ul>
unistylef
San Diego, CA
Decided to post a picture of my car. New chrome grill from broken_down. A new valve cover is at the powdercoat shop; gonna have it wrinkle red with shaved lettering. Hope to have the driveshaft rebuilt next week. Still have squeaky suspension... /ubbthreads/images/graemlins/bawling.gif
LIV4PSI
O-H-I-O
Only one picture huh? Don't show it off too much /ubbthreads/images/graemlins/wink.gif
unistylef
San Diego, CA
Okay, so a huge amount of things have been happening with this thing lately...
Check out this vid to hear it's first startup after cams and other exhaust elements installed.
More details once I get it looking respectable. /ubbthreads/images/graemlins/smile.gif
unistylef
San Diego, CA
Decide to be less reclusive and post a couple update shots. Rarely driven the past 6-9 months. Photos were touched up a lil. The car has a bunch of dings, blemishes, scuffs, and peels... but it has promises & aspirations for new paint and more custom work next year.
Displaying the beautiful 3" Stainless Steel, mandrel bent exhaust mated with a Magnaflow muffler hanging solid.
Showcasing 12.5" rotors and 3KGT Calipers on a 5 Lug swap. Rims will soon be changed out.
An above/ 45 degree shot of the car flaunting JDM headlights and a plastidipped 89 Grill. Also missing a cladding.
Underneath, the Evo 8 Bilstein struts are mated with Swift lowering springs.
Underneath, its not too shabby. You can see the car's catless setup in the distance.
The engine bay. Not glamourous, but thought out. Ceramic coating, powdercoating, porting, all wherever feasible.
Closer look, underneath is an EVO 3 16G attached to an EVO 3 exhaust manifold.
An ETS FMIC lurks behind the uncut bumper.
unistylef
San Diego, CA
Decided my car needed a personality when it starts taking on its new form. I like to consider this thing a monster, a green monster. I did some research and found the Kappa. It's a scaly humanoid salamander with a beak that is typically green. They are mischievous, but can be tricked into helping people. More Here
Wow Car is looking great man! might wanna do something about that manifold heating up that pipe.
unistylef
San Diego, CA
Quoting GSX_TC:
You really think this is an issue? What is your recommendation? Ceramic the J Pipe?
unistylef
San Diego, CA
Just a couple images displaying new tires and Evo9 rims.
A big shoutout for CutlassJim (James Rushing) for making (Stage 1) of my plan happen! This guy is an expert mechanic and professional at best.
More later.
youtube video: click
Nate
Worcester, Pa
I'm pretty sure I drove that car when it was still new at the dealership. Either that or 997. /ubbthreads/images/graemlins/smile.gif. Looks nice!
slugsgomoo
Tacoma, WA
Quoting unistylef:
Quoting GSX_TC:
I'm sure coating the pipes wouldn't hurt anything. I'd probably just get the factory manifold heatshield, since it'll bolt right onto the manifold you've got and they really do work. If you've got a factory-ish o2 housing, I'd run that one too unless alternator swaps and trips to autozone are fun for you.
unistylef
San Diego, CA
Heres a couple badges I made to give the interior a little more character.
this nameplate will be placed behind the shifter on the console
this is the kappa. not sure where to put it yet
unistylef
San Diego, CA
Hey everyone! Its been a long journey, but I am no longer in New Hampshire and now in San Diego. I cant wait to work out the kinks and start meeting people in this region!
