94 eclipse transmission for 91 galant
HugoF
New member
France
Hello,
The use of sex cam tags also helps users discover new and exciting cam models who cater to their interests.
raptorWagon
Oak Harbor, WA
Not without the turbo flywheel and turbo clutch. the NA 4g63 fwd cars run a 215mm clutch vs turbo uses a 225mm clutch and bigger flywheel. Gear ratios are different. Turbo fwd FD: 4.153 vs a 1g fwd (6g galant is probably same as 1g fwd)
