91 VR4 starts briefly and then dies. Car is mostly stock, and has repaired ecu
ou812
Member
Klamath Falls, OR
I have not messed with my VR4 in a couple years, but need to get it running properly again. Had the ecu repaired, as it had cap leakage issues. Now, even when swapping with a known good ecu, the car will fire right up, but then die in a few seconds. I am thinking that the fuel shuts off, or possibly ignition? I havent dug into it yet, but wondered if there is a good direction to start looking before going out in the cold!
thoughts or suggestions?
thanks,
Jeff
presterone
brunswick maine
Even with you pumping the gas pedal? Does it idle briefly or just fires....dies...fires.. Dies. Pop a vac Line and have a friend spray starting fluid or carb cleaner to see if you can keep it going.
Also my car did this similar thing with a bad maf but it would stumble and studder briefly as I was trying to open the throttle to keep it running
Wookalar
Arizona USSA
If the car has been sitting for years it will need the fuel drained and new gas. If you are anywhere north with moisture, snow or rain there is likely water in the gas.
ou812
Member
Klamath Falls, OR
car will not keep running, with throttle, full or anything in between.
Yes, before firing it again I will drain out the fuel....not fun, but necessary in this day of ethanol gas.
I will have to get the battery charged, and give it a go this weekend....
Find the MPI relay. Check if it clicks off when the car stalls. I know you state a "known good ECU" is being used, but that is the classic sign of the damaged ECU fuel pump circuit cutting out.
There is a way to jump the MPI relay to keep it running (would not recommend long term, but works short term). I have gotten disabled cars running again this way a couple times.
Wizardawd
Franklin, NC
In that same sense, MPI relay is probably fine, but from sitting for so long I feel it's more of a bad fuel/fuel pump issue. Starting then stopping right after is almost always a fuel issue. And most premium gas should be non-ethanol, but still doesn't like sitting for longer than 6 months.
Wiz
