91 Talon turbo TPS Help
wfovr42
New member
CS, Colorado
Working on a 91 talon turbo awd, runs like crap when u give it gas, hesitates and surges when u give it gas. Owner took it to the dealer and they said TPS was bad. I put an Ohm meter on the #2 and #4 to watch the resistance as u open the throttle. It starts out fine until its gets to about 1.3 ohms and then goes down as u continue to open the throttle. Does the exact same thing with the new TPS installed. any ideas? Im thinking its not the tps. Thx
fourforty
Active member
soth saint paul, MN
i am sorry to nitpick. but obviously you are new. i would ask that you take the time to use proper spelling and so on. it makes it easier for us to read and in turn help you out. if you fell that the throttle is giving the right signal, check wiring. if that isn't the problem it may be another sensor or at the worst case scenario the ECU could be fried. more explanation will always help us tell you where to look.
badams
KC, MO
^^^ Proper spelling? Did you read what you wrote?
Coltsfan
Tonawanda
The problem is probably the idle switch or closed throttle switch. The throttle stop is a switch; make sure it switches.
wfovr42
New member
CS, Colorado
I checked the throttle stop switch and it is not switching consistently. Thought I would run down the the parts store and pick one up, no go! Nobody has them, not even the dealer. Are they fixable or do you know of another source to get one?
Thx
Coltsfan
Tonawanda
I must have a half dozen used ones laying around my shop. Are you sure there's sufficient slack in your throttle cable? I have never seen one of those switches fail. You could probably find it on more than one model of Mitsubishi too if you have a junkyard in your area.
PS. You should also make sure the switch is adjusted properly. If the throttle blade closes against the bore, you may need to screw the switch in few more threads.
