91 galant 929/2000
vr4demon
New member
olympia
Hey everyone, I just bought Galant 929/2000. I have some info on the car but I am looking for more info. Right now I am mainly trying to figure out what the switch in the engine bay does, what the switch in the center console does, and what is done to the transmission. I have seen a few posts about this car on here so I figured someone might be able to help me out. Any info you have is greatly appreciated
vr4demon
New member
olympia
Ok, I found out that the switch in the center console does nothing. The other switch is in the back of the engine bay and looks like a kill switch but It doesn’t do anything when switched. It is a normal toggle switch with a red cover. One wire from it runs to a ground and the rest go to a wire harness near the bottom of the intake manifold. Also I went to get a new bov spring and realized I dont know what bov I have. I can’t find any branding or part number on it, does anyone have any ideas?
Vr4Ape35
Active member
New York
Aftermarket switch, you'll have to ask the previous owner and or trace the wires. Not related but where has your battery been rerouted?
vr4demon
New member
olympia
IMG_1956.jpeg Sorry it’s been a while since I’ve been on here. A few days after the last message somebody decided to road rage at me and caused a rear end accident. I am still dealing with insurance stuff but I will hopefully be buying the car back, doing a tube front end and turning it in to a street legal drag car or a rally car. I know how rare these cars are so I would like to make sure this one isn’t sent to the crusher, but it depends on what the insurance gives me for it. To answer vr4ape’s question the battery was rerouted to the trunk, I personally liked this more than the stock location because it opens up the engine bay and allows you to run a bigger battery. It’s pretty easy to do you just have to find a way to secure it in the trunk and then run the wires to the back.
I will definitely post a build series on here if I do keep it, so keep an eye out for that.
noglets
Active member
coeur d alene, idaho
View attachment 3657Sorry it’s been a while since I’ve been on here. A few days after the last message somebody decided to road rage at me and caused a rear end accident. I am still dealing with insurance stuff but I will hopefully be buying the car back, doing a tube front end and turning it in to a street legal drag car or a rally car. I know how rare these cars are so I would like to make sure this one isn’t sent to the crusher, but it depends on what the insurance gives me for it. To answer vr4ape’s question the battery was rerouted to the trunk, I personally liked this more than the stock location because it opens up the engine bay and allows you to run a bigger battery. It’s pretty easy to do you just have to find a way to secure it in the trunk and then run the wires to the back.
Damn man I’m sorry that happened, where are you located if you don’t mind me asking
vr4demon
New member
olympia
Everything happens for a reason. This just gives me a chance to build the car and make it even better. Im located in Olympia wa.
I have a friend who has a base model front cut if you want, located in north Idaho
I might be interested, but it will be a while before I get done with all the insurance bs and actually get a chance to work on it. I am 17, work 30 hrs a week, in full time college and part time highschool. I also have 3 other cars that need work so it will be a couple months before I get to it. If I do end up wanting it I will dm you.
