904/2000.
pinky
New member
louisville,ky
I'm pinky, or nekko whichever you want to call me.
I just did a trade and for a galant vr4, if been looking on getting one for awhile.
Former own claims it has a 2.3 stroker 6bolt engine
Now problem is.
Doesn't build boost.. Doesn't want to run, had a safc on it at one point it's fine, the maf looks like a stocker but wires has been messed up, it does have a bigger then Stock Turbo
But it's far from a good runner.
So I hope to learn and rebuild this dream car of mine. And contribute to the forums as well
Thanks
strokin4dr
Savannah, GA
Post some pics of the car and the wiring so we can see what you are starting with.
An easy way to measure the engine stroke is to pull a spark plug, grab a 12" skewer (or anything that can sit on the piston without scratching it up), and insert it into the spark plug hole. Then turn the crankshaft my hand with a wrench. Keep turning until the skewer (and piston) is at its lowest point then make a reference mark on the skewer even with the top of the valve cover.
Next, turn the engine again until the skewer (and piston) is at it's highest point. Make your second mark and then measure the distance in between the two marks.
88mm = 2.0 L
100mm = 2.3 L stroker
There are also some other less common stroker setups that would measure 92mm stroke, etc, but you will not likely see this.
Good luck.
pinky
New member
louisville,ky
Ok got some pictures trying to find a good place to unload them at.
Measured the stroke and came out 100mm so I guess, I do have a 2.3 stroker.
pinky
New member
louisville,ky
Going to try using the 3.5in gm maf with maf-t and 550 rc injectors and a ported 16g and alot of tlc to get it back into running condition.
I know the 3.5in gm is a bit big,and going with 3in piping would drop my boost pressure 2-3psi( just a guess) but would it fun eh ok till I get a better set up?
Or would it be better to keep is 2.5 then jump up to 3.5 and back down to 2.5 before and after the maf
It would be better not to use the GM MAF and MAF-T at all. They typically are horrible to tune, and work like sh*t compared to other MAFs that are available for these cars.
What are you tuning the car with?
pinky
New member
louisville,ky
I was trying to do a temp fix just to get it running to move it from his shop to mine with maf-t
Then go with a socketed ecu and dsmlink
