90 trans in a gvr4 also 90 ecu?
thedsmguy
Vancouver Washington
Just got a great shifting 90 transmission in a parts car. Any issues other then shifter cable swap? Also has a 90 ecu that was keydiver chipped for 550cc and 2g mas and 2 step etc. Should I just swap the wires or can I simply swap that chip into my eprom from my gvr4?
belize1334
Bozeman, MT
^^ Not sure about that one. Seems to me that we have '91+ style ignition coils so we probably have the same era tachometer which is incompatible with the '90 ECU.
The transmission is easy cheesy if you have a 22-spline t-case. You just have to swap the cable bracket and the left-right selector arm.
TRBODSM
Northglenn, CO
I put my buddy's DSM link from his 90 talon into my 91 GVR4 and had no problems with it. I am sure a chip would be the same way but keydiver would be the one to ask on that.
belize1334
Bozeman, MT
Oh, my bad. I thought he was wanting to swap the ECU in. The chip itself will swap no problem so long as your ECU is socketed. The ECU itself is different though so it doesn't swap directly without some work.
stevep
St. Charles, IL USA
Quoting belize1334:
Sorry you have it backward. The later cars don't have any major issues with a 90 ECU other than swapping the pins.
