90 Oil Cooler Mounting Location
Hey guys, I was wondering where everyone is mounting their '90 oil cooler. I have the complete setup and I am frustrated that the lines are too short to mount the cooler on the passenger's side. Currently, it's mount between my FMIC and my slim fan. It's way too tight in there and I need to find a better place for it. If it matters, I have a jdm bumper. Any ideas are appreciated.
atc250r
Orange County, NY
Search through some of my old posts. I'm pretty sure in one of the threads someone asked the same question and I posted some pics.
John
jepherz
KC, Missouri
Sounds like you are in the same boat I was when I had a cooler and lines. I eventually just ditched the cooler and lines and made my own. For the added cost, I got brand new parts, lines that I could run anywhere, and I knew that it would cool better than the '90 stock oil cooler. Best of luck to you.
slugsgomoo
Tacoma, WA
not to mention you can be sure nothing bad has ever gone through the cooler/gotten lodged in there, etc.
As coolers are so cheap, I consider them to be an item that gets replaced any time something like spinning a bearing/turbo failure/etc happens. Not worth taking the risk.
Setrab cooler running vertically behind the grille (on the left side as viewed looking toward the car). Ran my own -8 lines across near the bottom of the radiator to a '90 filter base.
Mike R.
quasimondo
Nairobi, Kenya
If you replace the stock lines with some AN fittings, you can mount that cooler in the same location that the stock intercooler would go, which coincidentally is where the oil cooler sits on the JDM RS models.
