90 OFH turbo oil feed?
rdomeck
Indianapolis, In.
I am switch to a 90 OFH and I am currently feeding my turbo from the OFH. I am going to run a filter on the inlet of the turbo so I don't think it will make a difference, but thought I would try and grab the filtered oil if I could.
Thanks
rdomeck
Indianapolis, In.
Sorry, I should have read that before posting....It didn't make much sense to me either after I read it!
I don't know which port to use to feed the turbo? There is a port by the oil pressure switch that points forward and another one that is lower that points down. Which one should I feed from?
Thanks
rdomeck
Indianapolis, In.
Thank you very much. That's exactly what I was looking for. I searched for OFH and oil filter housing....Didn't think to pull out filter!
