88 vr4 front jack point and remove sump cover
Hi all,
Q.1
was wondering where to place a trolly jack to lift the front wheels off the ground. also would like a rear jack point location, I have the diff to lift both wheels of the ground.
Q.2
Can the sump cover be removed without removal of engine was as i have some rust on the sump cover.
any help would be good
Cheers
Ivan
atc250r
Orange County, NY
I usually place the jack on the bar that goes across the front end just behind the radiator. In the back I put the jack under the rear diff. By sump cover I assume you mean oil pan? If so, yes it can be removed without taking the engine out.
John
thanks John re jack point
and yes i do mean oilpan with referance to sump cover and would i be removing the transfer case to do this.
and can a noobie like me do it without damage to the oil seal
atc250r
Orange County, NY
Yes the t-case has to come off. I believe it has 5 17mm bolts holding it in and as long as your careful you won't damage anything.
John
thanks again john its going to be a big job soon. teach me not to buy a jspec car again they salt the roads there.
atleast I only paid $750 bucks for it and it goes fast
atc250r
Orange County, NY
Odd. Most of the metal bits of the JDM parts I've seen were in relatively rust free condition. Its really not a big job at all. A couple of hours tops. If fact, I think that if you unbolt the carrier part of the two piece axle from the block, you might be able to slip the pan out easily without taking the whole axle out.
John
You can do it without taking out the axle. I cant remember exactly but you might have to remove the driver side cross-member just for ease of re-installing. Its only got 4-5 bolts in it.
fivestardsm
Middle, Michigan
+1^^
The only time you can do a pan with out removing the axle, is when you have a one-piece drivers side axle such as in the FWD non-turbos, and the really early turbo FWD's.
Although, removing it no matter what, will ease the process!
