6 puck or 4 puck clutch
WaRrIoRs16
Ferndale, WA
I'm looking into which clutch disk to buy for 796. I'm between an ACT 6puck sprung and an ACT 4puck sprung. The 6puck sprung is $20 more expensive so price isn't a factor. I will be mating it up with a ACT 2600 PP and a Fidanza aluminum flywheel all on a stock tranny, trying to get everything out of the tranny before it gets rebuilt. I'm going to be hopefully in the 450hp range with an hx35 setup and going to the track occasionally, but mostly it will see just "spirited" street driving. The car will split daily driving time with 628.
My street disk is slipping at 26psi on my 16g, so I doubt it will do the trick with the hx35 at 30psi. Thanks
WaRrIoRs16
Ferndale, WA
Alright, that's what I was leaning towards. I just don't want to get a into a situation where the disk can't hold up, or a situation where I don't every want to drive my car on the street because of how terribly uncomfortable the clutch is, hence the springs.
Barnes
Richland, WA
Now that my clutchnet 6-puck sprung is broken in, I really like it. If you want to see how it drives let me know. /ubbthreads/images/graemlins/smile.gif
BrandonEchols
Anchorage, AK
Quoting thecman02:
I'd go with the 6-puck. It is only slightly more aggressive, but will hold quite a bit more.
Wait...Am I confused or is this backwards?
I've always heard that:
4-puck: Harsh engagement (it's on or it's off essentially - there's almost no slipping it), wants to launch the car every time you take off but holds more power than a 6-puck.
6-puck: Smoother engagement than a 4-puck, but doesn't hold as much power.
I guess it could just be explained as:
Fewer pucks = harsher engagement & better grip.
More pucks = smoother engagement & less grip
Is that not accurate?
PreskitVR4
Prescott, Northern AZ
6 puck will last longer in our heavy cars. i had my solid hub 4 puck in the gay for a short while, logevity left something to be desired. it has to do with the fore-mentioned heat dissapation. the extra material reduces the clamp load, thus increasing drivability.
