4ws galant problem
Alaindicorsica
New member
France
hello i am new on the forum, thank you very much for your welcome, i am french excuse my bad english ...
I am the owner of a galant 2500 v6 24v 4ws from 1993, for 20 years, I wanted to see asking several things, is that a galant VR4?
I had a noise at the steering pump, 1 time a long time ago and since 4ws is Switch on . I changed all the steering oil but the 4ws is too Switch on in red light
that someone have an idea?
I also changed the steering wheel and SRS is Switch on /ubbthreads/images/graemlins/frown.gif..
I also want to know what is the auto scan diagnostic compatible with my galant (to erase faults)
thank you so much
idreamidrive
Murray, KY
No, it is not a vr4.
Not sure about the 4ws switch, did you bleed the air out of the lines in the rear when changing out the fluid?
Does the new steering wheel have an air bag? If no, then you will get the light. If yes, did you plug the air bag in? Still yes, you probably damaged a wire/clock spring when putting in the new steering wheel, or, I know on my car if I don't tighten down the nut for the steering wheel as hard as I can my turn signals don't self cancel themselves, maybe the nut isn't as tight as it should be and a wire can't make the proper connection.
Auto scan tool - Palm pilot (or windows computer emulating palm pilot), MMCd, and data cable
here is a google search I did, but you might be able to find more info in your own language click
