4G63 Maincap torque sequence need specs
Vr4junkie
Some wack town in CA
Ok so does any body have a picture of the torque sequence for the main caps I couldn't find anything beside the amount of torque to tighten them . Just nothing in the sequential order they go in I downloaded the overhaul pdf in the library but didn't find anything.
fuel
Toronto, ON, Canada
similar to head bolt torque sequence - except you do it in pairs. Start from the middle cap and tighten (but not to the specified torque just yet, perhaps half), then do the one immediately to the left, then immediately to the right and so on. Then go back and start tightening to the specified torque figure for each of the main cap pairs.
I always go hand snug first round, 20 ft/lbs second pass, then whatever the final will be. It differs if using OEM bolts or ARP, but yes, tighten the middle then next one out on the left then the right then the outside two. With the crank there is less to worry about breakage like with a cam since there is no springs pushing back.
JNR
ca
Not sure if you will be using anything on the threads? If so, remember to adjust your torque accordingly (will be less than dry)...
