#466/2000
Singlemalt
Member
Pennsylvania
Hi Everyone,
I'm a long time DSM/VR4 enthusiast and I've been slowly cleaning, fixing, and modifying 466 since around April 2014 and I'm happy to report that it is now back to daily driver status. I thought I would share a little bit of what I've been up to and where we are going. Definitely a work in progress but that's kind of the point. Anyway here are a few shots of how it looked when I got it. I plan to keep posting more updates and some of the stuff I've had to do in the last year and half to get it back on the road again.
The yard I got it out of
Profile before I started working on it.
Back in action
Singlemalt
Member
Pennsylvania
Thought I would put up some more pics of some of the first work I did when i got the car home.
Field mice had set up shop in the blower motor and hvac ducts.
I also noticed the massive driveshaft thump on the way home from picking the car up.
Luckily I had replaced the carriers on my eclipse at one point so I poached them off of it. While I was at it I made a set of mounting bushings and swapped out the lobro joint from my eclipse as well and put in some new u-joints.
Singlemalt
Member
Pennsylvania
Quick update.
I had a Starion intercooler that I bought years ago laying around so I cleaned it up and modified it to fit with the existing factory intercooler lines.
Singlemalt
Member
Pennsylvania
I needed a spot for a boost gauge and I've never really liked mounting stuff on the a pillar so I made one out of a gauge pod and an old piece of lexan to mount in place of the dash speaker
The original paint on the wheels was chipped and faded pretty bad so I polished the lips and gave them a rattle can respray.
Before
After
4Grim
Orlando FL
Glad to see you saved a GVR4...even better a Nile black! /ubbthreads/images/graemlins/cool.gif
Singlemalt
Member
Pennsylvania
Quick update. I was looking through some of my pictures that I've taken in the last year or so and I thought I would post a couple more.
I'm a cnc programmer and sometimes on the weekends if I'm at the shop I sneak in some side projects. I made a manifold heat shield out of a scrap way cover off one of our machines.
I painted with high temp vht and baked it in the oven one afternoon when the wife was away. Not much of a welder/fabricator but it turned out pretty good.
My 16g has all of the normal cracking around the wastegate but I went ahead and did a port and polish job and whipped up a 34mm flapper while I was at it.
