4 bolt ?
I've got a 4bolt rear..and latley I've been noticing that between gears and if I'm not smooth on the clutch, the rear seems to have some slack in it or something and it'll make a slight sound and almost like a "thud" sound..it dosen't sound harsh, but I don't think it's should be doing this ? any idea's ? I read somewhere about shimming the rear..but not sure.. I also get it sometimes when I abruplty let off the gas. I'd just liek an idea od what could be causing this, most likely it could be anumber of different thing..
gvr4ever
central Indiana
My stock rear end is starting to do this /ubbthreads/images/graemlins/frown.gif
The rear probably needs to be rebuilt. I havn't inspected the driveshaft joints yet tho.
Yeah, either your rear end is due for a rebuild or your drifeshaft u-joints are loose. Inspect your driveshaft if you can.
-Josh
Could also be a loose/broken/missing bolt that holds the diff in place.
Mike R.
powerplay
Norwell, MA
I replaced all of the spider joints and carrier bearings on my drive shaft and still have "looseness and noise" in the rear. I am pulling the rear next week and rebuilding it. New shims, seals and bearings. I am hoping that will fix it. As you have noted, it is the most noticeable when getting on and off the throttle.
powerplay
Norwell, MA
Just in case you want to rebuild your rear diff. here are the parts you need. They are all available from the dealership or parts vendors.
MR305708 4 pcs.
MR305709 1
MB569528 1
MD707184 2
MB393929 1
MB393955 1
MB393956 1
MB393957 2
MB185360 1
MB185350 1
MB241903 1
That will get you all of the seals, bearings and shim kits. It should come to about $200 for the parts.
nice, thanks for the parts numbers powerplay !
thanks for all the replies, powerplay, let
me know how the rebuild goes
powerplay
Norwell, MA
I was asked for additional information on this subject so hopefully this helps. These were the prices I paid at the time from the dealer.
MR305708 4 pcs. Washer $5.92
MR305709 1 pcs. Washer Set Viscous $3.95
MB569528 1 pcs. Shim, Viscous $5.12
MD707184 2 pcs. Oil Seal $6.45
MB393929 1 pcs. Oil Seal $6.35
MB393955 1 pcs. Bearing $21.45
MB393956 1 pcs. Bearing $22.87
MB393957 2 pcs. Bearing $22.03
MB185360 1 pcs. Shim Set $21.92
MB185350 1 pcs. Shim Set $20.71
MB241903 1 pcs. Spacer Set $6.92
Total: $189.94
Jesh
Soldotna, Alaska
i also have this problem when i had a 3 bolt rear and then i did the 4 bolt swap. the problem didn't go away, all my driveshaft u-joints are tight. i believe my transfer case has slop in it. not saying this is your problem, but just something else to consider. it would be easy to check and could save you some headache:)
