2nd o2 sensor removal?
kitcho
canada
I'm getting my exhaust done tommorow and the stock cat is coming out. However, there is an o2 (maybe a heat sensor?) post-cat that will have to be removed. What is the process for grounding it or whatever so that I don't trigger the dummy light for it once removed?
Thanks
/ubbthreads/images/graemlins/confused.gif
These cars don't have a rear o2 sensor. They're OBD1.
kitcho
canada
Okay, it isn't an o2, but ASA says "Sensor, Exhaust High Temperature" I thought it might have been some sort of heat sensor that would trigger if the cat failed? I can't read the warning in japanese on my sun visor.
Here's a pic of the sensor in question.
ktmrider
Tempe, AZ
Ah remember to remind us you have a JDM model in your posts.
Those are, like described, an EGT sensor. Subaru uses them on many of their EJ-T engines, doesn't actually measure specific temps per se but if a certain threshold is met it alters fuel/timing to help bring EGT's down.
Again using my Subaru experience we delete the probe and install a 2.2k ohm resistor across the two terminals. ECU still sees a "signal" and but not the danger threshold.
dandanger
Finland
They are just to warn about too Hot cat. They exist also on older jdm lancer evos. Just take the sensor off and put the wires together so the warning lamp doesnt light up constantly. Ive done so on my and no probs.
FlyingEagle
THE Ottawa
Maybe the OP would consider adding JDM and the appropriate car title to his signature? Just a thought.
Deleting these things would be fine in theory if they are only direct input to lights on the dash cluster and
have no real tuning repercussions as a result.
kitcho
canada
Quoting FlyingEagle:
My signature does say JDM and the year of car that I own...
FlyingEagle
THE Ottawa
Hey, my bad! I think my screen setup is different from other peoples.
I don't see sig's on my screen, just the post information.
Been a long time since I tweaked the settings on this site. /ubbthreads/images/graemlins/tongue.gif
