2g downpipe + 1g "catback" = no extension??
I did search, but I couldn't find an answer to my question /ubbthreads/images/graemlins/dunno.gif
So, I will install an E3 o2 soon and I also need a new exhaust system.
Will the 2g downpipe and 1g exhaust system eliminate the need of an extension??
If yes, should it be the "long" or the "short" 2g downpipe??
No, you'll need to stick with galant specific catback as the 1G has way less rear overhang. IIRC the 2G DP isn't bent correctly for our platform, and the difference between long and short is the long eliminates the cat, the short doesn't.
Quoting brunoboy:
You can use a 2 g awd dp and it eliminates the use of a cat and extension....
I stand corrected.
BluFalcon
Wichita, KS
I'm using a RRE 1G AWD EVO 3 Downpipe, Test Pipe/Cat section that goes into a 1G AWD Catback that's been extended for my GVR4.
Brunoboy
San Bruno,CA Home of SFO
Quoting 524of1000:
Being as I use to run that setup, If you use a 2g AWD DP and a 1g AWD Catback, you WILL still need an extension.
Extension is only about 6' isnt it?
Brunoboy
well I ordered the All Flow Cat from Siliconeintakes.com, It looks like a cat, just add flanges, so if you live in a state with smog. You'd be looking legal without being legal.
