So I was just wasting time at work cutting out holes in sheetmetal to just chuck at a trash can across the hanger, and it hit me:
\ for everyone running a external wastegate, lets say the spring is a 10 lb spring, couldn't you just shim the spring to increase the pressure, just like in some oil pumps, you add washers/shims under the spring to increase oil pressure, so wouldn't this same theory work, it would be alot of open and close on the wastegate but it you give you a very accurate/constant boost, without the use of a controller just straingt vacumn, well just throwing it out there,,,?
