Seems of late that my keydiver chip/ecu keeps losing the 2 step/stutter box setting each time I shut the car down is this normal? I seem to recall that it stayed at whatever rpm I set it to until I tapped the gas pedal on initial ignition on to raise or lower the setting. Now every time I start the car or turn the ignition on it resets to zero no stutterbox setting i.e. old boost gauge has no lights until I tap the pedal to reset it. Any ideas? thanks in advance.....
