2 cylinders misfire
OK let me start off with I'm new to VR4's but i do have plenty of mechanical knowledge. That said, my vr4 is misfiring cylinders 2 and 4. So i checked the coils and they are good, wires are good, plugs good. So basically it seems as if I'm not getting anything from the coil closest to the firewall. My only guess is that either the cam angle sensor is bad or the crank position sensor, now does that sound right? Any ideas would help, thanks.
Ok my mistake its not 2/4, its 2/3. I had 2 extra coils and i've tried both of them and still misfire on 2/3. I did not know that the capacitors needed to be changed, i will probably replace those within a week. Is it possible it is the capacitors?
Problem solved replaced ignition control module and problem solved thanks guys!
