2.3 question
Vr4junkie
Some wack town in CA
How reliable are 2.3 stocker s if I do go this route I will get a used crack from the junk yard but the thing that scares me is I been reading about people snapping cranks but who knows at what power level they were running. My goal for this car are 400hp max and aleast get 50kmi out of the engine will be using 1g rods
147/1000
Louisiana
Won't Last long with a used crack. /ubbthreads/images/graemlins/grin.gif
Seriously tho, if built right with a good tune and not beat on relentlessly it should last quite a while. I personally would use as many new parts as possible.
gramkrakr89
Bunker Hill, WV
Any engine, built properly, and used within it's practical operating limits, can last as long as you want them to.
Cracks with an unknown history should not be used in a build intended to last a long time /ubbthreads/images/graemlins/grin.gif
Vr4junkie
So a used crank might not be my best bet the car is mostly going to be a DD and weekendcar any one know how much a new crank runs for?
Vr4junkie
Ok what mitsubishi vehicle/year would be the best crank toget it from ??
I was planning on going with 2g pistons but I can get a used crank for $40 out the door at my local pick ur part and get forged internal for about 500 for the stroker
Jesus_Negros
USA
They can be found in the g4cs if you are looking for a 6bolt crack and in the 4g64 for the 7bolt crack.
As far as the 2.3 being reliable as long as its built right then it'll last years. The harmonics and lowend torque breaking trannies is what usually make the 2.3 "seem" unreliable but 400hp isnt much at all. makezdollars has been running his 2.3 for like 5+ years i believe.
raptorWagon
Oak Harbor, WA
Or a crank out of a 6 bolt 4g64 /ubbthreads/images/graemlins/tongue.gif. That myth of there is no such thing has been busted previously on here.
I personally went with all new parts with my 2.3l, expensive, but I was at the point the motor needed to be rebuilt anyway.
Terry Posten
Davenport, Iowa USA
I have a crank out of a 4g63 6 bolt. But the first thing I did was send it to a trusted shop and had it magnafluxed and measured to make sure it was good. I then had it cryro-treated just to make sure it was stable.
I am on year 3 all with a large framed turbo.
And yes, I have destroyed a stock GVR4 tranny 1st gear and snapped two rear 3 bot axles.
I have the rev limiter set at 7500 and it has never seen anything over 7200. It also has H-beam rods and JE forged sluggs.
However, I think I did kill the driveshaft driving it to the storage shed a month ago. It was making some nasty noises as it was banging against the floor pan. /ubbthreads/images/graemlins/crazy.gif
Vr4junkie
Quoting Terry Posten:
Did you go with a new or used crank?
raptorWagon
Oak Harbor, WA
Quoting vr4junkie:
Terry used a stock g64 crank, if you read the first two sentences of his post, he's on his 3rd year with it.
Jesus_Negros
USA
Quoting vr4junkie:
What would it take to turbo a 4gcs or 4g64 both 6 bolts I heard third have better rods ratio plus would be a 2.4
Swap everything from the 4g63t to the 2.4. If you are using the 4g63t dohc cyl head then you need to use 94 galant gs cam gears or adjustable cam gears. Thats all. The stock 2.4 rod ratio (1.50) is NOT better than the stock 2.0 rod ratio (1.70). You can slightly increase the 2.4 rod ratio by using 156mm rods but then comes a whole 'nother build. The g4cs and 4g64 both have a 235mm deck height and stock bore is 86.5mm. Other than that build it like its a 4g63.
Terry Posten
Davenport, Iowa USA
Quoting raptorreed:
Quoting vr4junkie:
The crank had just over 100K on it. That is why I spent the money on magnaflux work and cryo treating.
BTW - If you look at my "rides" thread, I have 360+ WHP. Running a very safe tune for 93 octane. By some fuzzy DSM math that is around 440 (+/- 15) crank HP range. 17ish PSI.
Vr4junkie
Quoting raptorreed:
Quoting vr4junkie:
About how much does it cost to service the crank with the Magnaglux and cyro treating?
Terry Posten
Davenport, Iowa USA
My local shop charged me $75 for the hot tank cleaning, magnaflux, inspection. The Cryo was $100 and they micro polished it after the cryro treat process.
Leon_R
Chelmsford, MA
Quoting 147/1000:
And why is that? Most people used cranks...
Just do not cut them down! But a simple polish job should be OK.
