1g rear differential internal parts compatibility
GTX
Toronto, Canada
Hi guys,
I wonder if anyone knows what would be parts compatibility list for the rear open diff for 1g. Mine is going bad, most likely I have to change spider gears. What are my options? On the other hand I'd prefer LSD if anyone selling
Thanks,
A
EMX5636
Bucks County, PA
Rear diff parts and assemblies from the 3-bolt are the same between DSM and Galant VR4. DSM 4-bolt diffs/axles/outer cups can be installed as an upgrade. If you still have, and want to retain, 4ws, then you need to use the diff case and differential housing with the gear from the Galant.
GTX
Toronto, Canada
Thanks guys! Very useful info! I was able to source the 3-bolt VR4 complete diff. Did not have a chance to install it yet. Look forward to it /ubbthreads/images/graemlins/smile.gif
