1991 Summit White Partout *UPDATED March 2023*
paul j
Lone Tree, CO
Do you have the two flanged bolts that hold the rear roll stopper arm to the block? 12mm x 28.5 long.
jmitch_z
New member
Missouri
Located in Hauppauge, NY 11788. Pickup preferred but will ship at buyer's expense + fees.
Pictures here:
Parts for Sale:Quantity:Price (each):Price (total):
door panel pull handle screw covers4.00$1.00$4.00
door panel rubber stopper (large) MB5749632.00$1.00$2.00
door panel rubber stopper (small) MB3218851.00$1.00$1.00
door panel screw holders (yellow)4.00$1.00$4.00
a/c switch1.00$5.00$5.00
abs relay MB1838651.00$5.00$5.00
center console felt tray1.00$5.00$5.00
driver underdash vent1.00$5.00$5.00
dummy window switch cover1.00$5.00$5.00
hazard switch1.00$5.00$5.00
mirror switch surround1.00$8.00$8.00
chrome door handles $102.00$10.00$20.00
dash speaker cover pass side1.00$10.00$10.00
dead pedal1.00$10.00$10.00
fuel door release bracket pin1.00$10.00$10.00
hood dampener MB021320 (small)1.00$10.00$10.00
pass side window switch2.00$10.00$20.00
center console side panel (L-shaped)1.00$12.00$12.00
brake switch (black + metal body)1.00$15.00$15.00
Crankshaft Bolt + Washer1.00$15.00$15.00
pedal clutch switch upper (black plastic body)1.00$15.00$15.00
plug in lighter receptacle1.00$15.00$15.00
upper steering wheel cover1.00$15.00$15.00
driveshaft to diff bolts (4 pcs 12mm)1.00$16.00$16.00
Balance Shafts2.00$30.00$60.00
center console lid1.00$40.00$40.00
Oil Screen strainer pick up tube1.00$40.00$40.00
1G turbo oil pan1.00$50.00$50.00
seatbelts assembly front center1.00$50.00$50.00
rods + pistons1.00$200.00$200.00
Do you have the upper seat belt assemblies? Interested in passenger window switch also
mk2davis
Ventura, CA
Any chance you have the plastic A pillar interior piece for the drivers side or the clear "VR-4" plastic piece just above the rear bumper on the right?
TIA
Dsmrt01
New member
Omaha
Do you have the rear inner rubber window track / seal for the front driver side door?
