18" Rims and 3kgt Brakes.
Nabeel
K.S.A
I am to buy new rims. I am looking for 18" rims. But I am confused about the offset as I am using 3000gt VR4 Brakes. The current rims are touching the calipers & had to use wheel spacers & longer nuts. I am not happy with the current setup as wheels are not matching the fenders.
Any advice what rims/ wheel offset size to pick?
Nabeel
K.S.A
Alaikum Assalam /ubbthreads/images/graemlins/smile.gif
So Zero to 30+ is the best offset for best fit/ looking for 3kgt brakes! Any one recommend rims brand will give more clearance for the Brakes?
Jesus_Negros
USA
LOL 0 offset is NOT going to work on DSM's or GVR4's. Starion can do 0 offset though! lol
bobdole
U.K.
The offset has nothing to do with brake clearence. Has to do with the rear pad of the wheel. Find a wheel you like and ask the company if they will clear bigger brakes.
kama1
q.c. philippines
Tackled this too not too long ago.ended up with +46 oem jdm 3kgt/gto rims.
Jesus_Negros
USA
Quoting bobdole:
Higher offset wheels are harder to fit over the 3kgt vr4 calipers in our cars. Unless you use 3000gt wheels which to me arent good looking on DSM's or GVR4's. Lower offset wheels fit better and give the spokes a better chance of clearing the wheels, I know for sure any evo 8,9, and X wheel clear the calipers. This is coming from personal experience.
JNR
ca
Also, the design of the spokes make a difference; meaning, how 'curved' they are in order to clear calipers...Not sure that the 3000 brakes are as beefy as brembos (huge width with 4+ piston) though, but imagine they exceed the vr-4 and dsm ones enough.
Was looking at my vr-4 wheels the other day and was amazed at how far back the rotors sit, with respect to being able to run a large caliper on them...the spokes stick out almost flush (never measured BS)and are thin and slightly curved, so all those help...they are 17's, so not sure it'd be big enough diameter though on say brembos with a larger dia rotor.
Jesus_Negros
USA
The 3kgt front caliper are 4 piston and pretty large compared to our stockers.
Nabeel
K.S.A
Actually I am still at 4 lugs so Evo or 3kgt are not an option. I still thinking lower offset will have better chance for bigger braks. At the same time avoiding having the rims out of the fenders.
I am sure someone here is using big brakes and can give an advice.
Jesus_Negros
USA
I used to have the 2kgt vr4 calipers before i parted my car. I think +28 through +38 offset will be good for you. How wide of a wheel are you thinking?
Quoting bobdole:
I'm in agreement with this.
Offsets can change regardless of spoke design. Some wheels just get deeper (bigger lip) as offset gets smaller, which means it would do nothing for caliper clearance. Imagine the outer rim moving outward but the spokes staying in the same spot in relation to the center of the wheel. It's all about the pad behind the spoke and the design (curve) of the spoke itself.
Nabeel
K.S.A
I ended up with this.... [ The offset has nothing to do with brake clearance ] . The wheel model & design make much difference.
