1172/2000 semi build
Sup guys i've been having 1172 for a while now. Had some issues with it such as blown turbo,and some wiring issues. As of now the blown turbo got me to do a little build.
As of now am waiting to install. I will try to keep updating as i go along with the build.
I have removed abs,ps,and gutted trunk. Waiting on 5lug swap. SSR Type c wheels buying from a friend.
Port and polish Head. Being sent out next week
65mm throttle body
ARP Head Studs
BC Springs, and retainers
Aem cam gears
Camshaft???? Don't which one going for Kelford, or HKS
Cometic HG
I have scm6052 but not sure if am going to use. I got a deal for a Brand new T-76 Ball Bearing
Aem Uego
3"in full exhaust.
Front mount intercooler
As Management not sure with either Mafpro,Or Ostrich.
Nice. What are your goals for the car? I'd return the Cometic hg & replace it with a stock hg.
My goals for the car is to make over 500hp and try to runs 10s. I See that everyone uses the mls gasket and some other the cometic am going to use this one since i already got it.
524of1000
San Antonio, Tx
^+1 on returning the cometic. I had just built the engine and the headgasket was leaking. NEVER STARTED IT, it just started leaking. ALOT. I popped in an OEM gasket and no leaks. Good luck on the build though!
Knock on wood, my gasket's working fine. I've always heard good things of the cometics. /ubbthreads/images/graemlins/dunno.gif Commonly used on dsm's
What are the bad issues with them? For future ref.
What would you guys the think the spool of a t-76 ball bearing spool with my setup.
