1g/GVR4 Upgraded Rear 4 Bolt Axles
M Wagner
Member
Lodi, OH
I present to you Wagxles, 1g/gvr4 4 bolt rear upgraded oem replacements. 26mm axle shaft, Rzeppa cv joints on both ends with a billet adapter so it drops right into your 1g/gvr4. I have had these on my galant vr4 all season with zero issues meanwhile last year I went through a plethora of oem rear axles since my car is a fat pig. These are now available so you can hit the 2026 season with confidence.
Shoot me a dm if you’re interested in a set these will require your inner axle cups as a core. $1,250. Keep in mind these are made to order.
Thank you!
- Mike Wagner
- WAGFAB
1.jpg 2.jpg 3.jpg 5.jpg 6.jpg 7.jpg 8.jpg 600289642_10173550069035651_1162892960113278814_n.jpg 600315158_10173550068210651_4846595896169044390_n.jpg 600911026_10173550068445651_527683926518282131_n.jpg
Are those 930 Porsche style CVs on the outer, or type 2 VW?
Do you use stock bolts through the outer wheel cup into that (aluminum I presume) adapter?
M Wagner
Member
Lodi, OH
These are 930 Porsche Style CVs, stock bolts will not work due to the shoulder on them(as you can see pictured from my initial test fit last year) these will come with all hardware needed to install.
